Search instead for
Nagging ScanGear Message
SMAAK
When using Multi-PDF for export, ScanGear shows the message box: "Scan completed. You can continue scanning. Close the scanner driver to end." And the option: "Don't show this message again." But the message box appears again and again and again... even when I activate "Don't show again."  How can I permanently kill this message.
I found a strange solution for the problem.
I had a scan profile named BILD.
I removed the capital letters, and renamed the profile to Bild.
After that, the message box disappeared and never was seen again.
Don’t use CAPITAL LETTERS in scan profiles!
5 REPLIES 5
ArthurJ
Hi SMAAK,
So we can better assist you, we will need some more information. Please respond to this post with the following information:
  1. What is the model of your printer?
  2. What version of Windows or Macintosh is installed on your computer?
  3. Is the printer connected directly to the computer with a USB cable, or wirelessly over the network?
  4. What program are you using to scan?
    CanoScan LiDE 400 A4 Flatbed Scanner
  1. What version of Windows or Macintosh is installed on your computer?
    Windows 7 Pro x64
  1. Is the printer connected directly to the computer with a USB cable, or wirelessly over the network?
    Directly
  1. What program are you using to scan?
    Canon ScanGear
ArthurJ
Hi SMAAK,
You can try removing and the reinstalling the driver and select to not show again. If the message still appears after that, troubleshooting with our support group will be needed to narrow down the cause of your issues.
Please contact our support group at 1-800-OK-CANON (1-800-652-2666), Monday - Friday, 8:00 AM - 8:00 PM EST(excluding holidays).
We look forward to hearing from you.
Is there any registry key or value for removing the message? Which I could add manually?
07/28/2022: New firmware version 1.2.1 is available for EOS-R3
07/21/2022: New firmware version 1.6.0 is available for EOS-R5
07/21/2022: New firmware version 1.6.0 is available for EOS-R6
07/21/2022: New firmware version 1.1.0 is available for EOS-R7
07/21/2022: New firmware version 1.1.0 is available for EOS-R10
07/01/2022: New firmware version 1.3.0 is available for PowerShot PICK
06/30/2022: Service Notice: EOS 70D: Error 70 or Error 80
06/07/2022: New firmware version 1.0.3 is available for EOS M50 Mark II
04/26/2022: New firmware version 1.0.1.1 is available for EOS R5 C
02/07/2022: New firmware version 1.6.1 is available for EOS-1DX Mark III
01/05/2022: Welcome to CES 2022!
12/7/2021: New firmware version 1.3.0 is available for Mount Adapter EF-EOS R 0.71x
12/7/2021: New firmware version 1.1.1 is available for CR-N 300
12/7/2021: New firmware version 1.1.1 is available for CR-N 500
