09-02-2017 06:12 PM
My MX922 printer continues to print double lines in the PGBK nozzle check pattern even after a manual alignment. Is there anything I can do to correct this short of a new printer? Thanks for your help!
Gary
10-07-2019 08:56 PM
I too have had the same problem (described by many) of printing double characters. I have three MX922 printers and love them, except for this problem. Two of them print double characters and one prints perfectly.
The problem has been very well described by Echobot on another thread. Here's a link to the thread:
Like others have suggested, I can change the black font to a colored font, and the problem goes away. I can also tell the printer that I am using matte paper then print with black and the problem goes away.
I called Canon tech support this afternoon and spent about an hour on the phone (most of it on hold). "Quinton," told me that my print head was warped. I asked him why I could print in color or with "matte paper" and the problem went away. He put me on hold for another 15 minutes doing some research. When he came back he told me that when you use colors, the print head uses different nozzles and when you use "matte paper", the print head uses the small black tank nozzles vs. the large black tank nozzles.
So I swapped the print head from my good printer to one that is printing double characters. Sure enough, the problem followed the print head. My good printer started printing double, and one of my bad printers started printing perfectly. Then I swapped the print head back, and the problem again followed the print head. I guess Canon tech support is correct. The double characters are caused by the nozzles used by the large black tank being warped (bad print head).
The posts I have read seem to indicate this problem starts after a year or two -- so I guess that is the life of Canon print heads. The solution appears to be to buy a new print head. Print heads cost more than a new printer (which is REALLY sad). So it all depends on how much you like your existing printer vs. the printers Canon (and others) are now offering.
10-21-2019 03:04 PM
Quick update on my last post. I did buy a new Canon print head and it definitely fixed the problem. No more double-line printing!
12-28-2019 04:32 PM
The PGBK was printing "double" on my Canon MX922 printer, The rest of the colors were fine. Cleaning the encoder did not work. I cleaned the print head, but that didn't work either. Then I replaced the print head (QY6-0086), with a new one, and it fixed the problem. New print head cost $70 from ebay https://www.ebay.com/itm/Brand-New-PrintHead-For-MX922-MX725-MX722-IX6820-MX727-MX925-QY6-0086/28290...
Before and After
12-31-2019 06:19 PM
I have this exact same issue on PGBK lines only. Wasted time on cleaning and re-aligning the heads. Glad I found this thread, so sound like a new print head is needed. This will be the third Canon I'll toss. Epson not so much better b/c I tossed 2 of them already.
02-03-2020 04:49 AM
Hi all... OK so I have the same issue with PIXMA MG1760. Its about 2.5 years old and has started to print the characters with double effect on about every 3rd or 4th line of text... but only with black text. ie if you have coloured text on the same page it's fine... but the Black is not.
BUT I found a work around... that works for me with the Pixma MG 7160.
When you go to print something (eg Word doc), go the "Quality and Media" setting and change "Plain Paper" to "Other Papers... High Resolution Paper" and it works beautifully.
However... it takes longer to print.
I don't use our printer that much so I'll put up with the slower speed... and saves me buying yet another bloody printer atm.
Cheers all.
02-04-2020 05:13 PM
I ahve the same MX922 issue. Paper selection does resolve it but is a "work around" fix. I don't believe the printer head warping theory as it would require warping overnight to be not present one day and then fully present and stable the next and that is highly improbable. Canon owes us a full and correct explanation and a fix that works permanently. Canon are you listening?
02-04-2020 05:31 PM
So the high resolution paper work around works, but does that mean it uses the BK ink and not the PGBK ink?
02-11-2020 08:18 PM
I have perfromerd additional testing on my MX922 and have discovered on my printer the only setting that prints double characters is Stendard.with plain paper. Business, Matte paper, Other photo paper all correct the problem. And again I doubt the warping theory as mine went bad over night in moderrate temperature too cold for thermoelastic effects to take place. Canon are you interested in solving this problem once and for all?
06-24-2021
09:22 AM
02:16 PM
Maybe this is it:
4. last but not least, a manual head alignment made again? Still no improvement?
Then you must assume that there is a defective electrolytic capacitor (capacitor) on the main board of the printer. This "manages" the electrical voltage that goes through the print head. Whereby the colored area (in your case BK + C + M + Y) and the PGBK head area are controlled separately. In any case, this capacitor no longer maintains the voltage correctly, causing these shifts in the vertical nozzle rows. This is basically a damage in the cent range, but very labor-intensive (printer would have to be disassembled, electrolytic capacitors would have to be measured and discharged, new ones would have to be soldered, and then everything would have to be reassembled) and is - basically - only to be done by a specialist... In this respect, an economic total loss remains.
@Message 23
My print heat is quite new
At least for a mg6350/MG6450 that does not work:
have same problem and the print head is not it. have 3 heads that go in other printers!
and i have tried print head replacement which works in other did not solve the problem!!!! i'm afraid cannon is a bad company. why isn't there an answer????????????????? they sure know what the problem is.
08-05-2023 12:20 PM
I have had my MX922 for about five years and double printing every other line or at random it appears sometimes, just started recently. I cannot be sure it started the print problem at the same time, but my PC also upgraded to Windows 11 recently.
