02-26-2022 01:25 PM
Ever since I downloaded Windows 11 this scanner stopped working.
Completely.
Cannot find a dedicated driver.
Has this thing become a boat anchor?
11-09-2022 04:23 PM - edited 11-09-2022 04:27 PM
Okay, thanks for your response. Maybe I was only viewing the CanoScan9000F Mk1 page, and NOT the Mk2 page?
I just went back to the CanoScan9000F, Mk2 drivers page and noticed there are Windows 11 specific drivers. I will install and test.
Also, which particular file should I install? Ver1.00 ? or Ver1.02 ?
Dave
11-09-2022 05:00 PM
I just saw your response above. What model Brother did you buy?
And I'm puzzled by your comment about their black & white printer. You don't mean that your new Brother scanner is also a printer? Or did you?
01-25-2023 05:14 AM
To make your printer work for pdf you can use NAPS2.
Worked for me. I´m so happy now : )
12-03-2023 08:57 PM
I came across this post with the same problem.
Canon gave me a fix which worked fully! see below
I emailed Canon from here (email link at the bottom of the page)
CanoScan CS9000F Support | Canon Australia
(or in text format https://www.canon.com.au/other-products/canoscan-cs9000f/support)
They responded quickly with:
Please be advised that upon checking our website, the driver and software is for windows 10 version only. We do not have driver and software for your CanoScan 9000F if you are using windows 11.
This is due to the age of the scanner, operating system requirements and other factors including design and features.
Just in case you are using windows 10 computer, you may refer to link below to download the Scanner Driver and MP Navigator. Kindly see link and setup instructions. Note: You may try this on your windows 11 computer, however there is no guarantee if it is going to work or not.
9000F Scanner Driver Ver. 16.0.5 (Windows 10/10 x64/8.1/8.1 x64/8/8 x64/7/7 x64/Vista/Vista64/XP/2000)
???????https://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDEwMDAwMjc3NTA0&cmp=ABS&lang=EN
MP Navigator EX Ver. 3.15 (Windows 10/10 x64/8.1/8.1 x64/8/8 x64/7/7 x64/Vista/Vista64/XP/2000)
https://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDIwMDAwMzk1MzAx&cmp=ABS&lang=EN
Setup Instructions
Download / Installation Procedures
1. Download the file. For the location where the file is saved, check the computer settings.
2. Double-click the downloaded EXE file to decompress it, then installation will start automatically.
3. Follow On-Screen Instructions.
If you require further information or assistance please reply to this email or contact Canon on 13 13 83
The problem for me seemed to be 1. Windows doesn't let you update the driver manually, it thinks it has the best driver, so the exe file does that for you. 2. The advertised drivers/scangear and MP Navigator apps do not recognise the scanner, but the one in the link above does.
There was just one glitch, after installing the driver first, then the Navigator app, the scanner had to be turned off and on again to get it to work after an error code came up. But all is working fine.
I hope it works for everyone
12-04-2023 11:03 AM
I've been using Windows 11 for many months and tried over and over to get Canon to let this scanner work with it. All to no avail, despite frequents requests. So I dumped this Canon boat anchor and bought an inexpensive Brother model that works fine. I'll never buy another Canon product again. Boo on them.
12-04-2023 11:20 AM
I am using NAPS2. You can find the software on the internet.
https://www.naps2.com/
I hope you haven't thrown away your scanner. Cannon quality is good.
12-10-2023 05:16 PM
Canon do still make Win 11 drivers for the Canon 9000F Mk2
https://www.usa.canon.com/support/p/canoscan-9000f-mark-ii
Canon do not make Win 11 drivers for the Canon 9000F Mk1
12-11-2023 02:48 AM
12-12-2023 04:30 AM
sorry to hear that, cant see the point in posting through? The drivers and the scangear program are working just fine with the links above on Win11 64 bit
12-12-2023 05:26 AM
12-04-2023 11:20 AM
