02-26-2022 01:25 PM
Ever since I downloaded Windows 11 this scanner stopped working.
Completely.
Cannot find a dedicated driver.
Has this thing become a boat anchor?
12-12-2023 11:25 AM
With the Win10 Drivers installed, my scanner worked under Windows 10 but had sporadic glitches. Since I've upgraded to Windows 11, with no extra work on my part, the scanner has been working very well.
12-12-2023 06:15 PM
I realize your post is almost 2 years old but wanted to pass on my experience. I recently purchased a brand new Windows 11 computer about 2 1/2 months ago. Wanting to install my Canon 9000F Mark II scanner on the new computer, I bought an external CD ROM drive then used the original CanoScan 9000F Mark II setup CD-Rom install disc that came with the scanner and it installed just fine. Haven't had any issues so far. Anyway, if you are still experiencing issues have you considered completely uninstalling all canon software, reboot the computer and then reinstall the drivers, etc from the original install CD? Just a thought. 🙂
12-12-2023 08:51 PM
Thanks to y'all who have provided support and helpful recent steps by Canon to make my scanner accessible for Windows 11. You are right that that these comments come some 2 years after my posting of woes. They come too late. I dumped that Canon scanner as a boat anchor, removed all its software and acquired my present Brother scanner which was very reasonable in price and fits al my needs, which aren't many or fancy.
I've had Canon cameras in the past that I have liked a lot (I now use a Nikon) so it's not the name I'm rejecting, it's the mouth-breathing nerds in the windowless Canon facilities with green eyeshades and Birkenstocks who released a scanner without Windows software and sat on it for two years/ Boo on them and their bosses.
10-23-2024 05:02 PM
Thanks for posting this!
I was in a similar situation moving from Windows 7 to 11 in one big leap! I used the above links and the scanner (original 9000F) works great. It actually is working better than it ever did under 7 where it frequently glitched and the OS would refuse to recognize it. This saves me from having to buy a Mark II model (many folks in the community have told me that the original actually works better for most applications).
12-02-2024 06:54 AM
I recently moved from W10 to W11 and had the same problem with my old Canoscan 9000F. I tried Vuescan and it worked but only in a basic way and not good enough for photographs and transparencies. I downloaded the above link and immediately accessed both 'scanner driver' and 'mp navigator'. My Canoscan is fully functioning again
Thanks to feltipen for publishing this information.
kwjg
10-29-2025
11:22 AM
11:25 AM
James_C
I tried using NAPS2but it does not scan negatives as far as I could ascertain. Feltipen's solution also did not work for me. VueScan did scan negatives but needed £159.99 for a one off payment. I did, using another PC on Zorin (Linux), download and use Xsane which appears to scan negatives it also has the ability to scan only those parts of the document that need scanning and not just the whole of it. Canon (finally) came up with this solution:
Unplug the scanners USB from the PC.
Next copy the file from your Downloads folder to C:\Temp (if you do not have a Temp folder create one)
Next rename the file from .exe to .zip
Extract the files.
Next left click on the DrvSetup folder
Right click on SETUP64.exe and run as Administrator.
Follow the onscreen instructions and plug the scanner in when requested.
Now click on Start > All > Canon Utilities > IJ Scan Utility and try a scan.
My PC is running Windows 11 via a Flybe get around and it does not work on this machine. However it did work on my wife's Windows 11 PC and I have used the option for negative scanning.
11-29-2025 07:24 AM
Thank you, Feltipen. Now my CanoScan 9000F is working with windows 11. Just using the Windows 10 64 bit version of the scanner driver and MP Navigator EX ver. 3.15. 😊 as you wrote.
