CanoScan LiDE 25 Drivers for Windows 10
Crackpot
I recently developed a need to use my old scanner. I dug it out from under the dust and seem to have all the hardware (scanner & USB cord). Downloaded the Quick Start Manual from online.
I cannot find the drivers for the Canon CanoScan F910111 scanner. They are not listed on the Canon Driver page.
Anyone know where I can find the drivers I need for it?
(No, I haven't tried just plugging it in to see if it will magically work. Probably should. 🙂
Any help would be greatly appreciated. Thanks 🙂
2 REPLIES 2
Crackpot
I just noted that this model seems to be the same as the LiDE 25, so I'm trying the workaround suggested for Windows 10 as Canon can't be bothered to update their drivers for Windows 10. They'd prefer you throw more money their way for a new scanner. If that becomes necessary because of this, I'll def switch brands.
normadel
If there is a Windows 7/8 driver, use it. I have extended the life of numerous last-supported-for Windows- 7-8-10- printers and scanners on Windows 11. It is very common. The underpinnings of 7-8-10-11 are very similar.
