03-11-2022 12:00 PM
I'm starting a new thread, since Canon people popped in once or twice on the prior one and seem to have ignored it since then.
I have a Canon R40 ImageFormula scanner. A few months back, it stopped working. The included software wouldn't work. Said it had a "TWAIN" error. I tried every suggestion folks put out there. Uninstalling and reinstalling the driver, the whole software package, etc. No luck with any of that.
So I have a useless scanner and an ever-increasing stack of documents I can't scan. It may be that a Microsoft update changed something and that started this whole issue. I wouldn't really know. I'm an end user, not a tech guy. What I do know is, the device I paid Canon hundreds of dollars for isn't working. I'd really appreciate a solution. For that matter, even some courtesy, where a Canon representative says, "yes, we know, and we're working on a fix" and a timeframe for when this will be done would be nice. Can someone please get on this?
Thank you.
03-20-2022 01:03 PM
Pardon my ignorance, I'm technically challenged, but for those of us that don't know, just where "exactly" does one look to find . . . . "the "Restoration Tool for Windows Registry" found on the Drivers and Downloads page under the Utilities tab". I haven't a clue as to how to find what you indicate is a solution for this issue that Canon is blaming on someone/something else.
Thanks
03-20-2022 01:18 PM
or search for "Canon R40 Driver".
03-24-2022 04:27 PM - edited 03-24-2022 04:28 PM
Hello.
Windows defender and other security programs have the ability to shut down communications for the scanner or to stop essential services from running. Your security software will have settings that will let specific apps and services through. You would need to allow the Canon applications through for them to run while the defender is on. If there is a problem with the registry and it prevents the computer from properly opening the twain folder where the computer stores the scanner drivers, it can also cause issues. You can download and install the restoration tool for the Windows registry to resolve the issue using the link HERE. You will find it under the utilities tab. If you need assistance with getting the scanner to work properly with Windows 11, you can also contact our support team at 1-800-652-2666. Our agents would be happy to assist.
03-24-2022 05:11 PM
Thank you, Cannert! I'm hoping I don't jinx myself by saying this (and wind up back here in a couple of days because it again stopped working), but this seems to have worked. I'm back in business and starting to catch up on my backlog of documents that needed to be scanned. Thank you !!!
04-02-2022 06:47 AM
I got through to Canon Support. They do not have a solution to this issue. They told me that more than just Canon are having problems with Windows 11 regarding basically a print-scan function. To me it sounds very much like we are stuck with rebooting Win 11 every time the scanner stops working. It also sounds like either Microsoft is the culprit or, everyone is just pointing fingers saying it's the other guy's fault. . . . . . reminds me of 4th grade all over again.
01-12-2024 04:10 PM
useless reply
12-05-2024 12:34 PM
I was able to get this to work using the TWAIN driver
12-20-2024 11:04 AM
ACTUAL SOLUTION TO THIS ISSUE
Install the "TWAIN driver" package listed in the R40 software downloads:
This doesn't update the scanner driver from 1.0.0 as per Device Manager, I think the relevant fix is with the "ScanServer" program. I chose the "modify" option during the installation for both prompts since I already installed the normal driver package.
This fixed the issue of CaptureOnTouch not seeing the scanner on multiple machines.
