11-16-2024 11:09 AM
Just bought the new Canon ImageFormula R40 and it will not work with MAC OS Sequoia. Upon trying to scan a document I get "CaptureOnTouch" is damaged and can't be opened. You should move it to the trash.
Do we have an updated driver (I dont see one) or a workaround? Otherwise I will have to return this product.
#imageformulaR40
01-11-2025 04:42 PM
Thanks Harvey.
If possible, please do paste in the full email, even if you have to split it across multiple posts.
even just the link would be great.
I was able to get it partially working with the Mac OS 14 version but it’s still janky.
01-13-2025 01:48 AM
harveysnyderiii can you tell us what MacOS and what processor you are using? I just submitted a support request like you suggested and will see what they say. I have the Mac mini M4 Pro running MacOS Sequoia 15.2 which does not appear to work with the current Canon software. The R40 support page seems to show no support past MacOS Monterey V12.
01-15-2025 05:31 PM
I just got this reply from Canon support which states there may be a new driver coming:
"Thank you for contacting Canon product support. I apologize that the driver has yet to be updated for the latest Mac operating system. I assure you that our Engineers are working on updating the drivers for all our products. Our engineers got access to Sequoia at the same time it was released to the public. They will get to the R40, but we do not have an estimated date. Please consider that they also need time for testing drivers. As soon as an updated driver is available, it will be added to the Canon website. Please let us know if we can be of any further assistance. Thank you for choosing Canon."
Fingers crossed this becomes a reality as I do prefer the Canon scanning software.
01-26-2025 08:47 PM
New software was released:
CaptureOnTouch (for Mac)
Type
Software
Date
01.15.25
File Size
108.13 MB
https://www.csai.canon.com/support/p/imageformula-r40-office-document-scanner
02-16-2025 09:51 AM
I followed your steps so I too can get help with getting the Twain driver for my MAC OS version 15.3. However, I don't know where I can find the email portion so I can contact Canon too. I am having lots of frustration looking how to resolve this issue, so I can use my new R40 scanner. Or if someone from Canon reads these, can they please assist me in this process. Thanks...
02-16-2025 01:33 PM
5 calls to Canon customer service, & I finally got a solution for my Mac that now has my new RS40 working. Steps: Delete CaptureOnTouch from applications & disconnect unit from computer. Close all other programs. Next, go to Canon website & load the Driver for OS version Sonoma (even tho I have Sequoia. You don't need to reset your Mac for Sonoma). After Driver is downloaded, then download CaptureOnTouch (COT), following the directions about when to reconnect the RS40, etc. I have now successfully several hundred photos & documents on my new RS40. I did have to repeat the entire procedure once when I was trying to reset the dpi & CaptureOnTouch locked up on me. Hope this helps.
04-17-2025 02:57 PM
Hi jmyers5645!
This information has been passed on to some customers via email regarding some errors that have been occurring with using the imageFORMULA R40 scanner on a computer running MacOS Sequoia. Some have reported getting a message saying the scanner is not being detected. Others have reported getting a message that CaptureOnTouch is damaged.
First we recommend that the scanner be connected directly to a port on your computer (not through a hub). If you are using an adapter with that cable, it can cause a problem. It would be better to use a USB cable that has the proper fittings on both ends. For example, if your computer has oval-shaped ports, please use a cable that has an oval-shaped (USB-C) connector on one end. The other end of the cable should match the connector that the scanner uses (USB-B).
If the scanner is properly connected and you continue to get the error (Scanner not detected or CaptureOnTouch is damaged), we recommend restarting the computer, and then uninstalling the driver and software. After the driver and software are fully deleted (trash is emptied), you should restart the computer again before attempting to download and install the most current versions of the driver and software.
IMPORTANT: Please use a different web browser to download the driver and CaptureOnTouch. For example, if you originally used Google Chrome to download the driver, please use Safari instead. Or if you used the Firefox browser, please use the Google Chrome browser instead. The CaptureOnTouch damaged error can be happening if the software is not being downloaded properly, so switching browsers can help.
You can follow these steps to uninstall the driver:
To uninstall the CaptureOnTouch program, please do the following:
After you have emptied your trashcan, please turn the computer off (shut it down completely) and then restart it. When it has finished restarting, please use a different web browser to open the following website and download the latest driver and software. As mentioned before, if you originally used the Google Chrome browser for downloading, please use Safari instead.
https://www.usa.canon.com/support/p/imageformula-r40-office-document-scanner
When the page opens, please click on the symbol for Software & Drivers located to the right of the picture of the scanner. Then, make sure that Mac and macOS Sequoia are selected as the Operating System and Version under the Downloads section. Once you have done that, the driver and software options will appear below.
Please disregard the order that the files are in. The TWAIN Driver may be the second option on the list and is dated 4/19/24. Please install the driver before you install CaptureOnTouch which is dated 1/15/25.
To install these items, you need to click on the Download button first (on the right side of the page). Once the file has finished downloading, please go to your downloads and open the file. Then, follow the instructions that pop up.
Once the Twain Driver and CaptureOnTouch program are installed, please do the following:
After the computer has finished restarting, please open the CaptureOnTouch program and try using it. If you are experiencing the same issue, I recommend making a change to your computer’s Privacy setting so that the CaptureOnTouch program has continuous access to the driver while you are using that program.
We do have an online article that should help with this issue. It asks you to go to the Privacy tab in your Security & Privacy folder to make a change. The article was written for older versions of Mac; however, the change that needs to be made is the same.
The only difference will likely be how you get to the Privacy tab. On a computer running MacOS Sequoia, you would do the following:
Once you are in the Security & Privacy folder, you can click on the Privacy tab and follow the information mentioned in the following online article:
https://support.usa.canon.com/kb/s/article/ART177783
If you are still having trouble after you make this change, please try restarting your computer one more time (while the scanner is turned on and connected). If that still does not help, I recommend calling us so we can help you over a phone conversation. You can dial toll-free 1-800-652-2666, Monday - Friday 9:00 A.M. - 6:00 P.M. ET (excluding holidays).
I hope this information helps.
04-22-2025 02:11 PM
Thank you Javier this worked perfectly for me. Thank you for taking the time to describe each step in so much detail, this made if finally possible to fix this and allowed me to continue using my R40--both with the Canon Software and my VueScan software on my M1 Mac Mini, using Sequoia 15.3.2.
06-30-2025 03:13 AM
Go to Canon's Canadian site, and they have downloads up to Mac OS 15.
06-30-2025 03:14 AM
