11-25-2025 03:58 PM
When I visit this page: https://www.usa.canon.com/support/p/imageformula-r30-office-document-scanner
to get drivers for my scanner that stopped working after upgrading to windows 11 nothing is listed there except plugins.
I need to get this working and I figured I would trying reinstalling CaptureOnTouch. I deleted the software so that I could reinstall it and now it is no where to be found. Does anyone have any idea where I can get this software?
11-28-2025 03:48 PM
You will want to download and install the CaptureOnTouch Lite updater program. Please visit the following website:
IMPORTANT: Please use Microsoft Edge or the most recent version of Chrome to visit the download page. We do not recommend using the Firefox browser to download our updater.
When the page opens, please click on the symbol for “Software and Drivers” to the right of the picture of the scanner. Then, make sure that the correct Operating System and Version is listed under the Downloads section. Next, please scroll down to the bottom of the list and click on the LOAD MORE button.
After clicking on Load More, please do the following:
When the scanner turns back on, please check if the CaptureOnTouch Lite program is available. If that program does not load on your computer screen (or if you are still getting the same error when trying to scan), please try restarting your computer (shutting it down and restarting it) while the scanner is turned on and connected.
11-30-2025 09:43 AM
Same problem, but can't find a solution. Have updated CaptureOnTouch Lite (says it's up to date when installing) and reset registry settings all per your instructions. Is there no way to uninstall and reinstall the drivers? That would seem to be the best solution. Thank you.
12-02-2025 04:08 PM
I apologize, but there is no driver for this scanner. The software “called CaptureOnTouch Lite” is built into the scanner and does not require a driver to use it. When you use a USB cable to connect the scanner to the computer, the CaptureOnTouch Lite software is uploaded.
Since the update did not resolve the issue, it is recommended that you call our support team at 1-800-423-2366 Monday-Friday 8:00 am to 6:00 pm ET, excluding holidays.
We look forward to hearing from you.
04-10-2026 03:17 PM
Hi. I also have the R30. When updating the firmware, the updating software crashed and quit. The scanner is not detected anymore. When I plug it into the USB on my Windows 11 laptop, you can hear the sound that a device is plugged in, but it does not load the scanner software. When I look in the Device Manager, the scanner is there, but it has a yellow exclamation on it and it says there is no driver. Is there a way to restore the device to it's factory settings? Thank you!
04-14-2026 04:09 PM
Please leave the scanner disconnected from your computer for 15 minuets. While the scanner is disconnected, please restart your computer.
After the restart, reconnect the scanner and power it back on to see if CaptureOnTouch lite will launch. If it does not launch, please contact us at 1-800-423-2366, Monday - Friday, 8:00 AM - 6:00 PM EST (excluding holidays).
