11-20-2018 04:07 PM
Hi
I have tried for a long time to make a wifi access point on my C100 MK and control the camera from my IPad - but no luck. I have tried YouTube tutorials - I have followed the user manual and my IPad is able to find the WIFI hotspot vreated from the camera, but I get the message "no internet conection" - have you made this setup work and any suggestions what might be wrong?
Thanks and greetings.
04-25-2019 11:59 AM
forgot to mention I am trying to set up 3 C100 Mark IIs to the same wifi. It seems to me that i may need 3 seperate IP adresses
08-02-2021 02:13 PM
Hi Tim
I went to "New Connection" but it's grayed out. Any ideas?
Ted
08-03-2021 01:55 AM
Hi tedfrank20,
Do you already have a connection with another Wi-Fi network? If so, are you able to select the edit option?
It might also help to disconnect any accessories or connections to a computer, as a test to see if you can isolate the issue.
Beyond that, you may wish to go into the menu, navigate to the wrench icon and then select RESET to restore the camera to default settings. Then you could try setting up a new Wi-Fi connection.
08-03-2021 09:40 AM
thanks Nick. I'll suss it out
03-18-2024 03:47 AM
Thank for the info for all. It is working great. I will use this feature all the time from now on.
