11-04-2021 05:12 PM
running windows 10, 64 bit
When I scan from the printer, the default setting is to scan in color, and save as PDF. However, when we scan , it saves as a JPG. I've tried restoring original default settings, and also tried using colorful language (neither solved the issue, though cursing made me feel slightly better). This isn't too terrible when it's only one page, but i often need to scan mulptiple duplexed pages into one document.
I have the mf scan utility installed, but this printer is not next to my computer (shared printer) so i haven't experimented with changing the settings and scaning (and running back and forth across the building) using that
12-27-2021 04:15 PM
Hello Lycaeides,
The MF scan utility will control what the scanner does when you transfer a scan to the computer using the button panel. In the Mf Scan utility, you can click on the option for settings in the lower right and then you can click on the item at the top that looks like the scanner. Once you click on it, you will see the settings for the different scan options available on the MF269 operation panel. You can view the settings using the manual found in the link HERE.
12-27-2021 04:15 PM
Hello Lycaeides,
