Any Suggestions For Canvas Print Settings For Canon TS6400 All-In-One Printer?
BurnUnit
Whiz
Whiz
Is there a best method for making small canvas prints on a Canon TS6400 printer. It's an all-in-one printer/scanner combo and turns out great looking prints on regular photo papers. But this is not one of the Pro Series printers and seems to have no specific driver settings for canvas prints, only settings for more common papers like Gloss, High Gloss and Matte.
What started all this is a good deal I found at a local discount overstock kind of store. There was a shelf full of these DIY canvas print and frame kits. And each kit got you enough materials to make three of these 7" x 9.5" prints for $4.00. Couldn't very well pass up a deal like that.
So I looked for but never found any print settings for canvas for my very basic desktop combo inkjet printer. And all I found online were some downloadable print profiles but Canon only offers them for their Pro Series printers. Figured I'd try it anyway using the default glossy photo setting. The canvas sheet fed thru OK but the print colors were dull and lacking in contrast. I ran the same sheet thru a second time with the same settings to double print it and it at least produced a usable canvas print. I was kind of surprised that the second printing was as closely registered to the first printing as it was.
So does anyone have any suggestions on getting a decent canvas print in a single pass? At least something with better colors and a decent amount of contrast?
jrhoffman75
If it is coated canvas for inkjet printing the matte paper setting may be better.
5 REPLIES 5
jrhoffman75
Thanks for the suggestion. Easy enough to try and probably not something I would have tried on my own.
I think the canvas may be coated somehow but the instructions don't explain much, other than what side of the paper to print on. Even with making two passes on my first attempt the inks aren't bleeding thru the canvas. I'll try the matte print setting the next time. I hadn't thought about matte printing possibly laying down more ink. If that doesn't work I'll try overprinting it a second time again. Was just trying to avoid using the printer's color saturation settings. If I don't figure out something I'll probably not go back to buy a few more of these frame kits.
normadel
Is the material textured PAPER, or is it actual canvas CLOTH?
It's not textured paper. It looks like a tight weave canvas fabric and the same texture is visible on both sides. And the ink side is slightly lighter in oolor. I'd guess it's got some kind of coating to help it hold the ink better.
BurnUnit
Whiz
Whiz
Someone on the Focus On Photography forum suggested that I try the Soft Proofing function in my older Photoshop 7 version just to see what results I might expect from printing on canvas. But not surprisingly PS7 doesn't offer a setting for canvas.
Poked around bit online but so far haven't found any profiles to download that seem to be compatible with either PS7 or my Canon TS6400 home desktop scanner/printer. It seems that most or all of the vendors I've checked consider canvas printing to be in the realm of professional printers only.
As mentioned above, my next attempts will be using the matte paper driver settings and we'll see what happens.
