09-20-2017 02:10 PM
I recently purchased a MF634CDW direct from Canon for my home office. I set it up and seemed like all was OK, but my wife reported that the machine had an error message. I power cycled and then it seemed fine, but I now realize that whenever the device goes into sleep mode, and you send a print job, it displays an error message and you have to power cycle to get it to function again.
I am not using the wireless functionality and am using the wired network. Other then turning off the sleep mode altogether and accepting that this device has flaws, I don't have another option. I downloaded and installed the latest firmware but it did not fix the issue.
11-01-2019 12:12 PM
11-01-2019 12:32 PM
I don't recall, but I want to say they were silent. It took me like 15 tries, but I think it was because he didn't tell me to hit Home before every try. I accidently did that and it went in and he said yea, you have to hit home to start over again if it failed.
11-01-2019 12:56 PM
12-30-2019 12:09 PM
I've read through this thread but didn't see any solutions that included this...
https://support.usa.canon.com/kb/index?page=content&id=ART135243&cat=6471B002&actp=LIST
Has anyone tried turning off Energy Star certification's shutdown timer??
In order to qualify for the "Energy Star" certification, the printer must power down after being in sleep mode for more than 8 hours.
If you do not wish to have to perform a restart after the printer has been in sleep mode for more than 8 hours, you can set the Shut Down Timer to "OFF" (the default setting is "8 hours").
To change the Shut Down Timer, follow these steps:
12-30-2019 01:27 PM
Thank You so much for posting a solution. I believe my issue turned out to be caused by a Mac software Mojave update, after I updated to Catalina the problem totally disappeared. BUT thank You again for so considerate.
12-30-2019 03:14 PM
@interzone wrote:I've read through this thread but didn't see any solutions that included this...
- On the Tab Selection screen of the Control Panel, press
to select Settings/Adj. tab (
- Press the OK button.The Set./Adj. Menu is displayed.
- Press
to select System Setup, and then press the OK button.
- Press
to select ShutDown Timer, and then press the OK button.
- Press
to select "OFF", and then press the OK button.
I don't think that is an option on the MF634CDW printer. I believe I mentioned before that I went it and have it auto wake every day at 5pm and thought that worked, but don't think it made a difference. I have printed 2 more times over the past month after it has sat and was able to print. Think going under the hidden menu and doing that fix is what helped if it is still posted.
01-24-2020 06:28 PM
03-31-2020 12:25 PM
03-31-2020 12:38 PM
Been working fine for me. I haven't printed in a couple of weeks and just printed twice today without issue. Haven't had a problem since turning that on. I'm pretty sure that is the fix now.
Now the toner cost....wow! I just run out of my initial starter batch that came with the printer and to replace all it's like $300. Canon, that is ridiculous!
03-31-2020 12:59 PM
