MF634CDW Not Waking from Sleep when print job is sent
itguy
I recently purchased a MF634CDW direct from Canon for my home office.  I set it up and seemed like all was OK, but my wife reported that the machine had an error message.  I power cycled and then it seemed fine, but I now realize that whenever the device goes into sleep mode, and you send a print job, it displays an error message and you have to power cycle to get it to function again.
I am not using the wireless functionality and am using the wired network.  Other then turning off the sleep mode altogether and accepting that this device has flaws, I don't have another option.  I downloaded and installed the latest firmware but it did not fix the issue.
79 REPLIES 79
msgtjk
Interzone said it.
Cashxx, I was finally able to get into that menu to change the 0 to a 1. Thank you
Oh, forgot about that post.  I commented I think right after he posted that and said I think that was for another printer that he was talking about.  Wasn't for the MF634CDW.
msgtjk
Got ya! Thank you! I’m just hoping the secret menu thing worked. For anyone who, like me, needed to see it being done, I included a link to a YouTube video. Check it out it does work.
https://youtu.be/lZuIcLjcOPE
msgtjk
He did it for a hard reset but I put the video to show him getting into the secret menu
All:
We do not allow posting instructions on how to get to "hidden" menus. These settings are not intended for public use, and can cause your printer to operate in a manner in which it was not intended.
If you're having issues with your printer that have not been resolved by troubleshooting steps posted by the community or our Subject Matter Experts (SMEs), please visit your My Canon Account HERE and reach out to support for one-on-one assistance.
If you're outside of the USA, please click HERE to contact Canon in your country or region.
Thank you for your understanding and cooperation.
This is a common issue with this printer and Canon should have the instructions posted on how to fix the problem then or fix the driver or firmware so that it isn't a problem!  Never had an issue with any other printer not waking from sleep when you print to it!  Not having instructions on the Canon site and calling in and waiting 45 minutes for the same fix isn't an option!
msgtjk
On another note, anyone know the diff between the 045 and 045H toner? Is the H a bigger capacity ie more pages?
Are you accessing your printer via WiFi? If so, are you set up with a designated ip address? Have you tried accessing the internal web server? Determine your IP (available through the menu) . URL is http://your.ip.addr/index.html. Even if your printer is sleeping, you can access the web server administration panel. Usually, accessing that will wake the printer. I set up a link on my desk called PrtWakeUp to access the admin server before I sent a print job over. To facilitate that I set up the printer with a set address. Long story short, eventually discovered that using a set address cured the problem. My guess is the lease on the IP was timing out and a new IP wasn't leased until a request went out and there was a disconnect between what the printer's address was and what the PC thought it was. Of course, if you are using USB then this won't help.
No, the only thing that worked was turning on a function that keeps getting deleted on here.  Simply visiting the webpage doesn't kick this model on.  Printer is connected directly to router via cat5 with static ip.
I'm here 2 months later with the same problem. I know how to access the required menus, but it seems like the actualy flag the needs to be changed got removed by the mods. Could that be posted again, or is there another resource that says what option needs to be changed?
Holiday
