11-29-2025 10:15 AM
purchased a new MacBook Air with the Sequoia 15.6 operating system. My Cannon printer is MF634Cdw. I am getting error 10,202,3 then 10,202,1 when I try to scan. I can print wirelessly, but can't get the scanning to work,
I have updated the driver for the printer from version 2 to version 4.
Help please?
11-29-2025 10:31 AM
These are the drivers needed for your printer under OSX Sequoia.
Canon Support for Color imageCLASS MF634Cdw | Canon U.S.A., Inc.
The errors are related to software. I suggest you start over. Uninstall any Canon Drivers or Utilities. Drag from the Applications folder to the Trash Can.
If you are using a USB connection, unplug the cable and remove the printer from Printers and Scanners using the minus (-) icon. Then restart your MAC. Run the printer installer first, do not connect the printer until you are prompted to do so. Then run the Scanner Driver/Utility. Retest
If you are using Wi-Fi or ethernet, remove the printer, restart and run the installers found in the link I posted above for Mac OS Sequoia.
If you are using
11-29-2025 10:17 AM
Thanks for joining the conversation, RL330!
This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or register your Canon gear HERE to access additional support options.
Thanks and have a great day!
11-29-2025 10:31 AM
If you are using
11-29-2025 11:25 AM
I bought my cannon aser printer around 2020. I thouhgt it was registered with cannon. I have registered it now.
I again, downloaded updated drivers and software for a 2nd time but i am still getting the error. can you help me?
11-29-2025 11:28 AM
Sorry , i didnt see you last reply, I will try that.
11-29-2025 11:52 AM
Thank you, this worked!
11-29-2025 01:46 PM
Great news! Happy Holidays.
