06-08-2022 04:07 PM
Good day. I have been using the abovementioned scanner for a year or two without problems. However, as from the start of this month (June 2022) I have been unable to scan and email documents (via gmail). The error I receive is 839. I have checked / reset all the settings:
SMTP: smtp.gmail.com / User account (valid): [email protected] / Password is set correctly / TLS for smtp is on / Port 587 set.
2-factor verification is off for the email account
(I also created a new gmail account, with the same result).
I have noted that as from 1 June 2022 Google has changed its security settings and apps and devices that use less secure access (username and password only) have now been blocked. Could this be the problem?
Any advice will be appreciated.
Regards
06-17-2022 03:00 PM
Hello Trevorfw,
Since Google has disabled the option to use less secure has been disabled, you can also use Google's additional option to setup an app password. If you continue to have problems setting up scan to email after using an app password, I would suggest contacting support at 1-800-652-2666. Our agents would be happy to assist with getting the scan to email option back up and running.
06-17-2022 03:00 PM
Hello Trevorfw,
