EOS DSLR & Mirrorless Cameras
EOS 200D Built-In Flash Issue
I own a CANON 200 D DSLR. Recently I am facing a problem with its built-in flash. The flash fires, but there is no light in the images. They turn out completely dark, except for the light light I get from the camera exposure settings. I have Reset th...
Resolved! Canon EOS M6 shutter button AF problem
Hello everybody! I'm Manos from Greece and i have an EOS M6 (Great camera!) Today, suddenly, when i half press the shutter button to lock focus the camera do not operate as usual. When i half press the shutter button to focus, immediately takes the s...
Anonymous by Not applicable
  • 3917 Views
  • 3 replies
Resolved! EOS R Areas of Image Flash Black
re: EOS R mirrorlessSome white areas of pictures flash black, on and off. Kinda looks like a film negative. Is that something that can be controlled in the Menu or is it an in-need-of-repair problem?Thanks, Jake
ViperEye by Contributor
  • 6391 Views
  • 2 replies
canon R7 viewfinder display
Does anyone have information on the different colors (green, red, blue) that appear in the R7 viewfinder as you try to focus and zoom in/out?  It has come up a couple times when I zoom out that the colors inside the viewfinder change and will not all...
Resolved! EOS RP Will Not Turn on
Hello All!Has anyone had issues with the EOS RP not turning on? I have only used it twice and the second time it flashed a green screen with lines on it on the LCD screen then never turned back on. I am finding limited issues and have ran through the...
am8849er by Apprentice
  • 5110 Views
  • 2 replies
  • 1 likes
Canon mirrorless camera suggestions
I would like to see a Mirrorless camera, with 45MP, Face and eye focus tracking, manual shutter, no video at all for professional still photographers, and sports photographers.  Cut the cost. Maybe the R1?  If you want video an R1C?As a news paper Ph...
Babemgnet by Contributor
  • 18567 Views
  • 27 replies
EOS 6D Mark II Power OUT
My  6D MK11 which I have owned since October 2018 is not powering on.It has been working fine until I tried out a 300 2.8 L lens (in v good condition) I managed 3 photos and the power just went and never came back.Tried charging batteries, switching ...
2000D LCD screen black
My 2000D lcd screen went black at the beginning of a shoot. After the first shot, I tried previewing it but the screen went black. It works in movie camera mode but not in any stills mode.  I’ve tried full batteries and new SD card. Same thing each t...
EOS R7 Firmware Update fail
Hello,I am trying to update the firmware on my R7 from 1.0.1 to 1.1.0 and it stops at 81% and then fails. I have tried multiple times and have deleted the firmware on the SD card and replaced it and only have gotten the same results. Thanks,
pha1016 by Apprentice
  • 3156 Views
  • 5 replies
Canon Picture styles affect raw
I have done a lot of research and every source tells me that picture styles do not affect raw images. I did a test comparing the neutral and standard profiles and imported into Lightroom and I noticed a significant difference. Is there a way to chang...
5D Mark IV won't connect to Mac with Big Sur
Has anyone run into a problem with WIFI connect on a Mac with the operating system Big Sur? I have the latest upgrade software on my camera. I downloaded the latest EOS Utility for Big Sur. During the setup process where the actual connect to should ...
Luvphoto by Apprentice
  • 1424 Views
