EOS Rebel T7 Lens Compatibility
does a tamron sp 60-300 lens fit canon eos rebel t7
I currently have a Canon EOS 1300D and Im considering upgrading. The Canon EOS 1300D is a great camera and has served me well for the past 4 years and was also my first proper camera. I now would like to upgrade to something with better low light pre...
I am getting the error below when trying to setup the Web Service (it downloads the SSL certificate successfully prior to this).T6S-EOSUtility-Failed to Connect.pngThis guide is provided for the T6s (https://ihub.image.canon/linkcameraguide?name=EOS%...
When I point the camera at the sky to take photos of the sunrises etc...it zooms in and out but won't let me take the photo...also there is a big dot on the lower right corner..it works when I'm not pointing towards the bright light
I installed the latest 1.6 firmware and noticed anytime i hit the record button in 120fps it locks up the camera to the point that i have to remove the battery to get it to reset. After doing the battery pull sometimes it will actually record 120 fps...
Hi All, Is there an easy way to enlarge the image size while reviewing without using the touch screen? I would like to enlarge the image while looking through the viewfinder. Is there a button or wheel that could change the image size? I know I can ...
Hi All,I have been through the discussion boards and they have helped me to download the webcam utility. Initially, I couldn't see any connection between macbook and M50. After changing cables, I can now see a connection as the utility window opens w...
I am researching why I cannot find "RATE" button data on Canon 5D iv in EXIF data.When I press the "RATE" button on the back of the camera it will record the data on the CF when 2 cards loaded. BUT, when I use an EXIF extractor program the data canno...
I have a new R6, that stops video (power USB C or with fully charged batter) when external connected to HDMI monitor Ninja V - Atomos / ATEM mini Pro to a Mac Book pro. The sleep is turned OFF. Is there a setting or something I am missing? (My 2nd...
I've read you can only record 29:59 at one button push. Is there a workaround where it can record until out of memory or battery? Already tried latest firmware.
So I just updated my camera to the 1.0.3 firmware and then saw there was a new firmware for 1.1.0 But now my camera won't let me add any new firmware. It works just fine, it connects to my computer like always. But when I try to do a firmware update ...
Can someone tell me if there is a way to get the current shutter count on my Cannon Rebel T100 (4000D). I have tried some apps and none seem to work with the T100. Thanks!
Hi there. I am looking to connect my Canon m50 camera to my computer so I can live stream on Streamyard and/or Zoom. For some reason my MacBook Pro computer won't connect to the camera. I see the screen below.I have installed the Canon Web Utility Dr...
I'm not sure what the issue is. I am trying to connect my 80D which in the past worked perfectly, as recently as a few weeks ago. I recently picked up a R5C and I have been able to connect to my phone without any issues. When I go back to the 80D, ho...
| Subject | Author | Posted |
| 05-19-2026 01:06 PM | ||
| 05-14-2026 07:24 PM | ||
| 04-22-2026 11:08 AM | ||
| 12-18-2025 01:20 PM | ||
| 12-14-2025 10:25 PM |
