Cycling thru R5 Shooting Info Displays
DaBrownCO
Enthusiast
I have camera tab 7 Screen Info displays to cycle through 4 screens. It only is cycling through 3 screens as I keep pushing the Info button. And these screens don’t correctly provide the Info I selected for each screen. Any ideas?
David
Okay, Gwen from Canon support resolved the issue for me. I had turned off Exposure Simulation so that was the culprit. It was interesting to learn that the electronic level and histogram don't show up when AF is in face-tracking or eye-tracking either.
8 REPLIES 8
BurnUnit
Whiz
Whiz
Try changing the setting of the camera's mode dial. I think you'll find that different shooting modes will enable different menus that apply to that specific shooting mode.
That doesn’t seem to solve the issue. I was also wondering if that was the case. A dumb question, but is the correct way to view the different screens to just keep hitting the Info button?
Your first post was a bit vague and I may be confusing the MENU screens with the INFO screens. Which feature do you think you're having an issue with?
If you haven't already done so, you should download a copy of the Advanced User Guide.
https://cam.start.canon/en/C003/manual/c003.pdf
It looks like there is a menu that allows you to customize what items appear on the INFO screens. More detailed information starts on around page #132.
Sorry for being unclear in my first post. The issue I'm having is with the INFO screens, both on the screen and in the viewfinder. I do have the Advanced User Guide and was following that when customizing my screens. There is an ability to reset the screen views to default so I am going to try that.
It seems that it's the Histogram that is missing in some of the views.
Thanks for reporting back here with the fix. That's a couple bits of quirky behavior that you might have never stumbled upon on your own.
True on the quirky behavior although I do vaguely remember having the same issue with the histogram missing on my 6D many years ago.
Friends and Family
