EOS Rebel G compatibility with EOS Utility, film recommendations
hi! i’m a new photographer and i recently got a rebel g on amazon. i know it’s kinda old, but is there a way to put it on eos utility? and what film do i need for it?thank you!!!
On the R6 mk i, if i set the drive mode to 2 or 10 sec timer mode and use the BR-E1 remote, the shutter fires immediately (overriding the drive mode on the camera)But on the mk ii, this is not the case. The remote doesn't override the drive mode set ...
I'm increasingly getting the Error 01 code (The communication between the camera and lens is faulty) with both my lenses, so I'm guessing it's the body. Removing the lenses and putting them back on helps for a few shots, but then it's back to the err...
Hi Everyone, I was shooting a wedding two days ago and twice my R6 Mark II froze, the screen went black, and the only way I could get it working again was to remove the battery, reinsert it, and try again. When turned the camera back on I had lost ma...
Purchased Canon R5 body with lens on 4/29/24 for $4299. Discovered the price dropped to $3899 on 5/10/24. Contacted customer service, and they graciously offered to refund the difference.Exceptional service! I'll keep you posted once the refund is pr...
I have a 90D and EF lenses from wide to telephoto and macro. But thinking along the line that the lenses are more important than the body and I am not using the lenses to their full potential on a small frame, I am thinking of either the 5D mark iv o...
Hello I recently bought myself a Eos R100 and i have 2 issues going on right now, 1. The camera just shuts down saying overheated when it's been off with no battery inside (just started to happen) and 2. when i try to update my firmware it doesn't sh...
On the EOS R7 is there a way to quickly switch between back button focus and shutter button focus. Having started out on cameras with no BBF I find at times shutter button focus more appropriate. Thanks.
HiI got a strange problem with transfering images thru eos utility.Yesterday i connect the camera via wifi to eos connect utility and everything went fine and i downloaded all my images.Today i do the same thing but from the moment i select my images...
After I purchased the R5, I immediately had focusing problems with my long lens. I have an Canon adapter to use my older lenses. I was told I needed to upgrade my R5 software, and after I managed that, the focusing issue disappeared. After several mo...
Hi all, I have a strange issue with my Canon R5 EVF. After changing a battery, the EVF sometimes gets stuck in portrait format. i.e all the settings shown in the EVF have rotated round 90degrees counter clockwise. exposure compensation meter is on th...
Hi, every time I am putting manual mode on with my ring flash and attempting to take an image, the shutter goes off but the image is always back. I am using the camera for dental photography. I have been on a course and am using the same camera, lens...
Good morning, I am a beginner and was advised by my brother (who is a Nikon guy), to purchase the canon EOS t7. He thought it was an all-around decent camera to learn toggery fee, techniques, and still remaining in my budget. With that said, he advis...
The title basically is the question. I am shooting macro photography and I need to take a series of images and stack them. The way this is done in the field (I'm told) is to press the shutter and as the camera clicks off the frames, slowly move for...
I want to build a portable and effective setup so I want to slap a RF 28mm f2.8 lens on a camera for everyday carry.The RF 28mm f2.8 doesn’t have IS. The R6 has IBIS and the R8 doesn’t. However the R6 is marginally heavier and bigger than the R8 http...
| Subject | Author | Posted |
| 05-19-2026 01:06 PM | ||
| 05-14-2026 07:24 PM | ||
| 04-24-2026 10:39 AM | ||
| 04-22-2026 11:08 AM | ||
| 12-18-2025 01:20 PM |
