01-14-2023
04:27 PM
08:47 AM
I have results from my R5 that are disappointing at best. I've tried changing the settings using pros advice but still not as sharp as I'd expect. I'm using an EF 100-400 lens for BIF and have sent the lens to Canon for alignment, still no improvement. I bought the camera new and so far as I know it has never been damaged. IF, I get extremely close to my subject the image is a lot sharper.
I shoot wildlife and BIF using back button AF. Raw files and shutter release (mechanical). I use a variety of focus point settings and of course servo mode. I'm to the point I'm going to send it back to canon unless I find a miricle cure. I'm at 1.7 firmware as well. Any suggestions or similar complaints?
01-14-2023 04:50 PM
Mirrorless cameras track at all times even if you're not using certain focus points unlike a DSLR camera. What mount adapter are you using Canon or a 3rd party. Which version of the EF 100-400mm the original or the Mark II version. Can you please post some picture with the metadata intact in the forum. What settings are you using have you tried One Shot AF on a static subject just as a test instead of Servo AF. What is your shutter speed could you be seeing camera shake. Make sure IS is turned on unless on a tripod.
-Demetrius
Current Gear: 5D Mark IV, EF 16-35mm F/2.8L III USM, EF 24-70mm F/2.8L II USM, EF 50 F/1.8 STM, EF 85mm F/1.8 USM, EF 70-200mm F/2.8L IS III USM, 430EX III-RT, 470EX-AI & 600EX II-RT
Retired Gear: EOS 40D, Sigma 17-50mm F/2.8 EX DC OS HSM & EF 28-135mm F/3.5-5.6 IS USM
01-14-2023 05:32 PM - edited 01-14-2023 06:13 PM
Not the first time I hear about R5 and a focus issue https://community.usa.canon.com/t5/EOS-DSLR-Mirrorless-Cameras/loss-of-sharpness-100-400-using-R5-an...
There are more user reports at Dpreview.
I can't remember I have seen any about R6. My R6 has no focus issues.
01-15-2023 08:05 AM
“IF, I get extremely close to my subject the image is a lot sharper.”
If you are a long distance from your subject, then the camera could experience difficulty locking focus on your subject and not something else within the field of view. It goes without saying that tight cropping does not always produce great images.
Also, it has been my experience with that lens using UV or CPL filters can have a significantly negative impact on the autofocusing. If you feel that you need some sort of protective on your lens, then I recommend only using high quality Clear filters.
I use Clear filters to keep my front lens element clean, not for protection against impacts. There tends to be lots of dust, pollen, and other small airborne particles in the wild.
01-15-2023 10:27 AM - edited 01-15-2023 10:42 AM
" I'm at 1.7 firmware as well. "
It's not the FW. It is not a misaligned lens if Canon checked it out. It could be poor filters or even good filters if they interfere with the lens. Remove any filter and stop using them. Other than that keep in mind the lens doesn't know when it is in focus or not. The camera tells it. Further you tell the camera how this is to be done. I suspect that is the real issue.
"I get extremely close to my subject the image is a lot sharper."
All lenses lose resolution as distance increases. That's why closer subjects appear sharper.
" I've tried changing the settings using pros advice ..."
Well, IME, this can be both good and bad. "There are more user reports at Dpreview." I am not a review reader. You can't trust them. They can be totally wrong or give incorrect info or be downright lies. You just can't trust the reviewer to be what they claim they are. Some guys make career out of reading reviews on the ole inner web. They must spend hours doing so. Then they reply to posts like this with what they have read without any real experience of their own to back it up with. How do you tell the difference? I don't know but don't put too much stock in too many reviews.
"...have you tried One Shot AF on a static subject just as a test ..."
This is a good idea if nothing more to prove to yourself that there isn't anything wrong with your camera/lens. Easy to set up. Try different distances, too. So, lets reset the camera to default setting. Menu>tools>clear all settings and clear all custom settings. You always have to start at the known beginning. Set the camera to P mode. Use Raw always never jpg. Set ISO around 200. Use One shot and just the center focus point. Never Ai-servo or any other auto focus mode. Use a good tripod, a good one not a cheapo. The other settings don't matter because you will u/l to your computer into DPP4. If you don't already have it you can d/l it for free from Canon. Do the shots, u/l to DPP4 and examine them. You can/should apply Canon lens correction and any other tweaks you like.
How do they look?
01-15-2023 01:08 PM
Please get back to us with an example image.
Also please answer the questions:
The R5 has a very sophisticated AF system that's quite different from DSLRs and there's a bit of a learning curve with those newer AF systems. BIF are one of the most difficult subjects. There are a lot of videos on YouTube showing how people are setting up their R5, R6, R7 and R3 (all of which are similar) for wildlife and birds. Many people set up the AF On button for one form of back button focusing and the * button (AE Lock) for another such as animal eye detection, so that they can use the first to get the focus close, then switch to the 2nd to really lock onto the subject.
Are we getting anywhere with these questions and suggestions?
Alan Myers
San Jose, Calif., USA
GEAR: 5DII, 7DII (x2), 7D(x2), EOS M5, some other cameras, various lenses & accessories
FLICKR
01-15-2023 03:00 PM
I'm using the R5 with a Canon 100-400 EF IS II USM, the adapter is Canon as well. There is a Hoya UV filter on the lens. The static test is kind of inconclusive given that it seems to focus better at shorter distances. I have also used a Canon 70-300 lens with about the same issues. I am more than open to the idea that my own personal proficiency may well factor in and I am also aware that over crop will affect image quality.213A6119-1.jpg
01-16-2023 09:15 AM - edited 01-16-2023 09:16 AM
Stop using the UV filters. You do not need them. There is already a UV filter layer built into every digital image sensor assembly.
If you feel that you need a “protective filter”, then only use a high quality CLEAR filter. I recommend the B+W Nano Clear filters.
01-16-2023 10:06 AM
"Stop using the UV filters. You do not need them"
I repeat this. Stop using any filter. The ef 100-400mm does not like them.
01-16-2023 10:17 AM
Dennis,
I checked out your samples. It looks like you used ISO 4000 on some. That will enter a lot of grain in the photo and you might conclude that is the lens not being sharp. It is not. It is the granin factor. Also it looks like you are doing an extreme crop to the images. You can't do that and expect top IQ. There are limits to how much you can get by with. You have exceeded them. The short answer is get closer or a longer FL lens like a 600mm. Either one means you don't need to crop as much. One is free the other is not! I hope you are using Raw and you have DPP4. Both of these are necessary to anyone that wants top IQ pictures.
