EOS DSLR & Mirrorless Cameras
EOS Rebel T8i Settings for wrestling
I'm renting an 18-135mm IS USM lens for my Canon T8i and was wondering what the best settings would be to get great photos of wrestling this weekend. I haven't had much luck figuring out the best ones for other lens as some gyms having different ligh...
Resolved! settings for football using canon r5
hello i'm ShadowFox it's a pleasure to meet you all, i have a photoshoot at Sofi stadium this weekend I'm using my new Canon EOS r5 with a 24-105mm lens what are the best shooting arrangements/settings for slightly cloudy weather? my apologies for th...
EOS M200 Error 60
I turned on my canon eos m200 and the error appeared "ERR 60 lens error, it will automatically shut down and restart the camera" I tested it with another lens and it is working normally, so the problem is with the camera's original lens, I have alrea...
Jonatan by Apprentice
  • 7250 Views
  • 6 replies
EOS 1300D - wifi not showing up
my camera EOS1300D stuck on waiting to connect but i cannot see any wifi/network according to the SSID provided. i even tried to add new network using the encryption key with wpa2 and said network not found
tg794666 by Apprentice
  • 4137 Views
  • 2 replies
EOS Rebel T3 Sports photos coming out blurry
I have athlete boys so I purchased a telephoto lens EF 75-300mm so that I could take lots of photos of them playing sports. Although a beginner, I started off really well and the pictures were great! We are way into our high school season and I have ...
ltdeleon by Contributor
  • 20096 Views
  • 17 replies
EOS T7 rebel shut off after 12 minutes
My son bought a Canon t7 that he has given to me.  I'm trying to record 30-45 minutes videos on it.  However, it shuts off after 12 minutes of recording.  The answer is YES to the following: Is the auto-shut off actually off? Do you have a full size ...
Viewfinder/LCD agreement in 90D
In cold weather (~32F, 0C), when I try to change the autofocus type (zone, point etc), the state posted on the LCD does not match that seen through the viewfinder. As a result, it’s not clear to me what autofocus method I’m shooting in. Had anyone el...
EOS 6D Mark II not turning on
I know I've seen this topic before but not sure if I have ever seen a definitive answer. My two years old EOS 6D Markll camera will not turn on. I tried everything..New battery. New SD card. With and without the lens attached. Holding the shutter rel...
Corrupt .CR2 Files from Canon 5D Mark IV
The images above are from my current import of .CR2 files into LR. This has been happening EVERY TIME lately. I've formatted the card in the camera and re-formatted plus changed cards and it is happening every time.If I open with Lightroom or Microso...
Static discharge from Canon EOS cameras
Hi therei have a Canon EOS R7 with kit lens 18-150.i need to enter a petroleum plant for some photography work.checked the specifications but no mention of certification whether able to use the camera at the premises.will not be at refinery area but ...
Leo7 by Apprentice
  • 1976 Views
Resolved! EOS R5 Mark II - button customization
Hi, folks: I'm going through the process of setting up my new R5 Mk II. I'd love to be able to assign a button to enable/disable pre-continuous shooting, but I know that's not possible yet. (Hopefully in a future firmware update it will be.) Based on...
