08-03-2024
09:15 AM
09:19 AM
I recently purchased the Canon EOS R7 and EL10 flash. I took it on vacation and was in some caverns and it would not focus. I also had the camera on Program. Why would it not focus? Did I not have it set right? It focused fine outside the caverns.
08-03-2024 10:27 AM
In some shooting modes, the shutter will not release if focus cannot be achieved. Shooting inside a dark cave is an example of this. In this case, manual focus with flash might have helped.
08-03-2024 05:20 PM
Since you were shooting with a speedlite. The speedlite should've switched to Intermittent Flash Firing. Or the camera body would fire an LED AF Assist Beam. As long as the AF Assist Beam is set to Enable on the camera and NOT LED ONLY. Then on the speedlite set to Enable on the speedlite. Then the AF mode set to One Shot. AF Assist Beam projection method is dependent on the Ambient lighting. On wether the camera body or speedlites fired an AF Assist Beam. As a test put the lens cap and ensure that the focus mode is set to One Shot. Then the AF Assist Beam is enabled on the speedlite. Then ensure that it's set to enable on the camera body NOT LED AF Assist Beam ONLY. This will force the camera body to use the Speedlite for AF Assist. The Speedlite will pulse rapidly to aid the camera's AF system.
08-03-2024 06:30 PM
There is a time and place for flash. I come from a world of low light photography and needing flash. But flash cannot always be used. Look up Vanessa Joy on YouTube she can help you out with flash photography. She is a wedding photographer. Or you can look into a fast aperture lens like an F/1.8 or F/2.8 lens.
08-03-2024 06:41 PM
"The Speedlite will pulse rapidly to aid the camera's AF system."
And annoy the heck out of everyone around you, who are trying to dark adapt.
08-03-2024 10:27 AM
08-03-2024 02:54 PM
Thank you.
08-03-2024 05:20 PM
08-03-2024 05:55 PM
Thank you so much. I am trying to learn the EOS R7. Also, I try to stay away from using the flash whenever I can as I don't understand how to use flash. Your response helped me a lot.
08-03-2024 06:30 PM
08-03-2024 06:41 PM
08-03-2024 06:45 PM
Thank you.
08-03-2024 06:47 PM
Thank you. I will have to learn about the Speedlite pulsing rapidly.
