R7 EVF half blank
Mikie1
I was shooting at a sporting event with my R7 and EF 100-400mm f/4.5-5.6L IS USM (slide out zoom) lens with adapter. During the shoot, the lower half of the EVF went black. I didn’t do anything other than tracking and shooting (didn’t try to remove the lens while the camera was on or anything like that). The rear screen works fine, and the photos are still full frame, so it isn’t the sensor. I’ve tried shutting down and removing the battery several times, once keeping the battery out overnight, but it still only has half the screen. Has anyone run into this type of problem? I’m hopeful for an easy fix, but I am afraid it’s going to be an expensive trip to the camera doctor…
1 REPLY 1
Hazel_T
Hi Mikie1,
I'm sorry to hear half of your viewfinder went black. There aren't any settings on the camera that would cause that kind of issue. Since the bottom half of your photos aren't showing the issue, and it isn't happening on the rear LCD, that indicates the issue is specific to the viewfinder screen itself. Typically if it was the sensor or an issue with the lens we would expect it to show in your photos and the rear LCD. We would recommend sending your camera in for repair.
The Canon U.S.A., Inc. online repair portal allows you to set up service in a few simple steps. The repair portal gives you the ability to set up service for multiple pieces of equipment at once, and to receive a repair estimate in the majority of cases, depending on your model and issue. The portal also allows you to upload images or videos that will assist us in repairing your product. You can also select how you wish to be notified of the progress of your repair. The portal's service history section allows you to view all services that have been performed on any of your camera or video products since January 7, 2020.
Please follow the link below to access our online repair portal to arrange for service:
https://mycanon.usa.canon.com/signin
Instructions for Accessing and Using the Online Repair Portal
You will need to access or create your My Canon Account.
If you already have a My Canon Account and your product is already registered, simply click on the “Get Repair Services” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you have a My Canon Account and your product is not registered, you must register your product first. Click on the “Get Repair Services” link on the left menu, then click on the “Register Product” link on the right. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you do not have a My Canon Account, you will need to create one. After you create your account, click on the “Add Product” link to register your first product. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
Once you have completed the repair request, you will have an opportunity to print a copy of the request for your records. This request form will also contain shipping instructions and an address label that you will attach to the outside of your shipping box when mailing your equipment for repair.
Friends and Family
