I am a beginner with video. What software do I need to view .MOV files on my Dell Desktop?
When I magnify an image during review, can I save the magnified image? The camera is an EOS 60D.
I wish to control my 5DIII via the EOS utility, but I do not wish to download images to my PC, just record on the camera's card. Does anyone know if you can do this?
I have been really impressed with my t1i over the past few years and recently had the chance to pick up an old 300d. It was the body only so I ordered some batteries and used a cf card I already had. I went to turn it on and nothing happens. I ha...
I just sold my t4i and have about 700 dollars saved up for a new camera. im looking ether to go with the 70d or 6d theres certain things i like about each... i do like the tilt screen and it being touch also the dual pixal af and i want to get int...
Hi,I have a 7D that will not hold settings. It used to without any problem. Canon installed the most recent firmware update and I now seem to have problems. I don't know if the update caused the problem or if the timing is coincidental. ISO, f stop, ...
Hi, I am facing this issue continuously with my Canon T2I & Speedlite 430 EX II, when I use this speedlite, I don't get sharper images (most of them are Ok images) but if I remove speedlite and take normal shot with my camera, I get sharper images.It...
will the ttl flash units for the EOS DSLR's work on the M?
Rebel T4i - Is there any concern or issue with trying to reinstall firmware version 1.04 again even though I've already installed it on my camera? I am having camera issues that I never had with 1.01 and thought I would give this a try.
Is there a way to reset my T4i back to the factory settings if I can't access the menu settings? Such as a way to 'hard boot' the camera maybe by pressing a certain combination of buttons in a certain order? My menu and info buttons are not working...
So, after removing a battery from my camera, I heard a snap and now the gray clip that holds the battery isn't how it was before. It's like detached from the side, and it just fell. For the looks of it, it looks like it was just glued to the side of ...
I've been shooting with my T4i and 50mm 1.8 for almost a year now, and recently, it's autofocus is on the fritz. I manually select an autofocus point, but for some reason, it autofocuses on somewhere OTHER than the point I have selected. Is this an i...
I have a good supply of Lenses from my old EOS 650 canon. What rebel model should I buy for using EF 35mm film lenses? I want to stay under 800$US
| Subject | Author | Posted |
| 05-19-2026 01:06 PM | ||
| 05-14-2026 07:24 PM | ||
| 04-24-2026 10:39 AM | ||
| 04-22-2026 11:08 AM | ||
| 12-18-2025 01:20 PM |
