T3i metering with preset long telephoto
lin
I have a Canon T31 and a very good preset 500mm preset lens. In "live view" (mirror up) it exposes correctly. In normal (mirror down) overexposes by 1 or 2 stops. Metering mode is set to "evaluative" and everything else is equal. [Tripod and wired remote shutter release].
Any ideas?
27 REPLIES 27
"EDIT: Looking back, I now see that Tom said almost the same thing last night. So maybe it isn't so far-fetched after all."
Tom, is correct.  The one part that does not make sense is saying that the camera's aperture setting can be adjusted.  On a lens that is truly manual, the camera's aperture will read as "F00", and you cannot adjust it all.
If a mount adapter with focus confirmation is being used, then that might explain why the camera does not show aperture as "F00", because it fools the camera into thinking that it is adjusting the aperture, when in fact it is not.  This will also fool the metering system, too.
With a variable aperture , manual lens, the more you stop down the lens, then the greater the difference in exposure readings between the viewfinder and Live View.
Bob, can you please choose a larger font ?
I know I'm getting old but I can't be the only one who struggles to read your posts Smiley Frustrated
Thanks
Ray
bob from boston and lin,
"It's probably wrong, ..."
Right, it is wrong!
I use that lens. It doesn't and can't change its aperturte unless you do it.
EOS 1DX and many lenses.
Right, it is wrong!
Go back and read what I wrote. It may or may not be wrong, but it's based on exactly what you're saying. The camera thinks the lens switches itself between its full aperture and the preset aperture, but it can't.
Bob
Right, it is wrong!
Both of you guys have a valid point.  The aperture size does seem to fool the metering system, which the camera reads as "F00" on a a fully manual lens.  All of that stuff you mention about the camera setting an aperture at f/11 doesn't apply.
I am not sure what the camera is thinking when it shows an "F00"  aperture.  One thing is certain, though.  The narrower the aperture becomes, the greater the difference in exposure between the viewfinder and Live View.  You get the least differences in exposure at the widest aperture settings on the lens.
But, it could work the way you describe on some mount adapters that have a focus confirmation chip.  I have used one and I have to set the camera's aperture to match the lens aperture to get accurate exposures.  Doing so also causes the Live View exposure to nearly match that taken through the viewfinder.
Stephen
Moderator
Moderator
I'd like to weigh in, if I may?
Seeing as the lens is a Vivitar T-mount lens, the Rebel T3i has no idea what lens is connected to it (or that a lens is even connected). Even if you were to use an EF-adapter, my guess is that there are no electronics in this lens to communicate with the camera. In most cases, the camera will read "F00", like Wadizzle said above. That means either no lens is attached, or the camera doesn't recognize the lens.
We obviously haven't tested these lenses, so we can't guarantee anything, but we've found that they work best in fully manual mode, so  you can tell the camera what you're doing. Remember, the camera doesn't even know a lens is attached when you're looking through the viewfinder.
On the flip side, when you use Live View, the camera's electronics doesn't know about the lens, however, it can tell optically that *something* is there. That means that it will expose the shot to the best of its ability.
That's why the "automatic" settings will be all over the map, and remember, we guarantee nothing when you're using a non-Canon, non-EF/EF-S lens.
I hope that helps!
Thank you, very much.
Notwithstanding me earlier avoidance, I had finally arrived at the Manual solution.  Not only is that what the camera prefers (and responds flawlessly to), but at least for them of us who cut our teeth on non metering 35mm cameras (an Argus C3 & a Pentax H2a, in my case), the old rules of thumb like "sunlght 16" come back.
AND, these Canon SLRs are considerate enough to provide a great, easy to refer to metering system to confirm our manual efforts.
That lucid and concise explanation of what causes the different results was spot-on, so for all of the others wrestling with this, Problem Solved.
B from B,
"When you're in viewfinder mode, the metering system thinks it's looking through the lens at full aperture (f/8), so it adds a stop of exposure to account for the fact that the picture will be taken at f/11. But in live view mode, the camera knows it's already seeing the scene at f/11, so it doesn't add an unnecessary stop to the exposure."
This can not happen. That is why it is wrong.  If the lens is set to f8 the exposure will be measured for f8 and the T3i will complete it at f8.  If you wanted to shot at f11, you must manually move the setting on the lens to f11.  The T3i will then make the proper exposure measurement and take the shot.  I don't use live view so I didn't comment on it.  But it will not change either in my guess.  It can't.  The T3i meters whatever the lens is set on.
Manual mode and a fixed ISO will work (view finder).  I have done it thousands of times.  It is exactly how I use my old FD lenses.
