09-05-2025
02:43 PM
03:36 PM
Hello everyone,
Im travelling and I forgot my external wall charger. Is it safe for me to use my phone charger?
My camera is the EOS R10, and phone charger Samsung EP-T4510 (super fast charging).
Thank you!
Beatriz
09-05-2025 04:52 PM
I sometimes use a USB charger to charge my EOS R10. I use a more powerful charger, but all the same when the camera is charging the card access light will show green. When charging is complete the light will go off.
https://cam.start.canon/en/C006/manual/html/UG-11_Reference_0030.html
So I think you should be ok with your Samsung charger and the camera.
09-05-2025
03:33 PM
04:10 PM
Samsung doesn't have full specs listed for this device. 45w, 5A. But Volts = Watts / Amps.
In general, a USB-C PD device should be at minimum 45w, 9v, 3A. Note, the battery will not charge when the camera is powered on. It could work if the pin out matches. 😉
[Commercial link removed and replaced with screenshot to act as visual aid.]
09-05-2025 04:08 PM
Hi Rick,
Thanks for replying!
Sorry, I’m not too tech savy. Here’s a photo of my charger.
I pluggled it to the camera and it’s showing a green light. Is this normal? Should it not be an orange light or something, that would turn green when fully charged?
Thanks again for your help, really appreciated!
09-05-2025 04:12 PM
09-05-2025 04:52 PM
09-06-2025 03:32 AM
Thank you Brian! Have a good day 🙂
