Ink is full but colors are not correct
Not sure what the problem is...double checked everything, turned off and back on, etc. I have canon MX920. Any help would be appreciated. Thanks
Hello I machine Canon iR1024i.I can not establish a network to network scan.Fits on MFP ip address, install utilities iR ToolBox for a computer Win.7x64. run utilities, click scan and it gives me an error (A supported scanner is not installed. Please...
Hi All. I work from an Acer C720 Chromebook and, 'on advice', I recently bought a Canon PIXMA MG3650 printer as I was told this was compatible with my Chromebook. I don't seem to be able to get the two connected either with a cable or wifi - with ...
Canon 3600 series - received error code 5100 - ink cartridges were fine however, paper was jammed. Removed jammed paper, made sure no paper left in printer. Tried to print again, same thing happened. How do I fix this so I can print my documents?T...
code5,157,69... WHY and what is... I am renovating my study and temporarily move my pc and printer (MG 3560) into the lounge room... but now I cant scan anything... can still print... but cannot scan WHY??? and how do I replace it without buying a n...
When i select s file in -image Garden - to convert using OCR and right click, the OCR function in the drop down is grayed out. What is the prblem?
Three questions, First, I want to print in draft, I am using Mac Latest operating system. When I try to do this, using Preview or using Word, I am able to click on "media and quality" and am presented with three choices, one of which is draft. Howeve...
My PIXMA MX870 has a paper jam, but I cannot see the jammed paper. How do I clear the paper jam?
Will not buy another Canon - and advise others against.MP610: U052 "error" - Huh!UK.(I hadn't realised this site was Canon-sponsored, or I wouldn't have joined.)
Really Struggling. I scan a document on the machine. If I save it to my documents I can't edit it. It used to appear in my image gallery and now it doesn't. It is so difficult to understand the manual and the manual never mentions windows 10. Can any...
My MG5750 keeps telling me the printer is out of paper when it is not. What can I do?
How do I get rid off b200 error code? I've washed it in hot water cleaned to with rubbing alcohol nothing works. Printer is like new. Please help
How do I correct the problem. I have shut down the system and rebooted. The printer still won't scan. however it will print copies.
I am running a new macbook air ( OS 10.12.2) and my Canon MG7150 wont print. I can see the job in the queue but nothing is happeneing ( the printer is on, in range and on the same network ) . When I try and print a test pattern I get an eorror messa...
I have a Canon MG2560 All-in-one Printer....While putting in the new Colour Ink Cartridge.....I have accidentally jammed it and now it won't budge...Would anyone have advice to fix the problem?
| Subject | Author | Posted |
| 09-21-2026 06:05 PM | ||
| 09-21-2026 01:06 PM | ||
| 09-20-2026 05:36 PM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM |
