MX892 scanning to computer
driver
I have been using my printer to scan to my laptop trouble free for a couple years.  When I select SCAN on my printer it defaults to my laptop, and I can save the scanned document to my laptop very easily.  However, now I would like to change that default setting on the printer from my laptop to another computer.  I have successfully entered MP Navigator on my new computer and saved a scanned document to it, but, still, I would like to change the default setting on the printer so I can use the printer controls to scan to my new computer (instead of having to initiate the scan on my computer).
How do I change the default destination setting (for scans) on the printer from one computer to another?
Since no one cares to answer you I just had to figure this one out myself. On your printer press menu,  select setup, Device settings, go down to reset setting, Settings only, yes, ok, ok. Now when you press the scan button it will let you select pc again and you can set a different pc that is connected to it corded or wifi. Hope that fixed it.
9 REPLIES 9
Crista
Whiz
Hi driver!
To have a better understanding of your issue, please let everyone know what operating system (Windows XP/Vista/7/8 or OS 10.X) you are using. That way, community will be able to assist you with suggestions appropriate for your product.
If this is an urgent support need, please CLICK HERE to reach our friendly Technical Support Team by phone or email.
Thanks!
Windows 7
Ebony
Rising Star
Hello driver,
If you forward the data to the network-connected computer:
The screen for selecting to which you save the data is displayed.
figure: LCD
  • If the Scan standby screen for forwarding the data to the USB-connected computer is displayed on the LCD, press the left Function button (Save/Foward) to display the screen for selecting to which you save the data.
    figure: LCD
Select the computer to forward the scanned data following the procedure below.
  1. Select PC, then press the OK button.
  3. Use the UPDOWN button to select the computer to forward the scanned data, then press the OK button.
    The Scan standby screen is displayed.
    Note
    • If you select Local (USB) on the Select PC screen, the data is forwarded to the USB-connected computer.
           If you press the left Function button, the machine starts searching for the connected computers again.
Hey drizzt90...I'm impressed that you 1) accepted the challenge of figuring out my problem, and 2) were successful!  Thank you very much for helping me out.  I had been able to work around this setting on my printer, but it was bugging me that it just wasn't right.  I'll try to pay it forward...thanks again.
I have the same issue. I have followed your steps but for some reason on last step when I go Scan and select PC it does not show my computer to select.
I can print to my MX880 fine wireless, but after resetting, and selecting to Forward Scan to a PC my PC is not showing up ???
Any suggestions ??
Hi, Brundige1!
Which version of Windows or Mac is in use?
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at http://bitly.com/CanonEmail or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
Thanks!
Windows 7
Hi Brundige1,
When scanning from the operation panel of the printer, you will need to have the Canon IJ Network Scanner Selector EX program running on your computer.  To ensure it is running, from the Start menu on your computer, select All Programs, then Canon Utilities, then IJ Network Scanner Selector EX (folder), then IJ Network Scanner Selector EX (program).
Once the program is launched, please attempt to scan again.  If you still experience difficulty, please call 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays) and a Canon technical support representative will be happy to further troubleshoot the issue.  There is no charge for this call.
