Desktop Inkjet Printers
Scrambled lcd and scan
My Mx300 suddenly started to show mixed up words on the lcd. WhenI finally got it to copy something the image was 180o from where I placed it on the paten. It scanned the lower part of the page instead of the top and printed it upside down. Very stra...
Tomjay by Apprentice
  • 2369 Views
Ailignment Problem with Canon MG 3100
Have a Canon MG3100 Printer, Using Windows 7, Connected via Wifi.Replaced the ink cartridges, Printer did not perform alignment or print sample page. As a result, when attempted to print a document, the print was misaligned, how does one correct this...
Some1KJ by Apprentice
  • 45490 Views
  • 7 replies
MX922 doesn't print at all
I have been using MX922 for 4+ years without problem.From a couple of weeks ago, it simply doesn't print at all.When I tried to print/copy, everything "sounds" as usual (I can hear the sound that header is moving, while paper is fed)but nothing is pr...
kjyoun by Apprentice
  • 1967 Views
MX420
I use a Silhouette Cutting Machine.  I upgraded the program and now my HP Laptop says it can not detect my Wifi printer.  I see it listed under printers, but either idle or not connected.  I am trying to remove the device/printer MX420 to start over....
jeri5leo by Contributor
  • 3167 Views
  • 3 replies
Resolved! PIXMA MX922 Printing Question
Does the MX922 print using Legal Size Paper.  Mine does not have room in the Lower Tray for this size paper. Is there a tray for this printer that can handle Legal Size Paper? Thank you,Dee
DeesCT by Contributor
  • 4842 Views
  • 3 replies
PIXMA MX922 Scanner not working
I just set up our PIXMA MX922 All-In-One Printer. The printer works fine, but I cannot get the scanner to work. The Printer connected to the wifi network and the computer discovered the printer and installed it. However, when we open the scanner, a b...
jrrisk by Apprentice
  • 2414 Views
Resolved! Is print head alignment part of initial setup?
I'm trying to help someone over the phone setup their Canon printer.  They said a Print Alignment screen popped up and so they can't install their drivers.    Surely Canon doesn't make you do a print alignment during setup?  I find that hard to belie...
hayley3 by Apprentice
  • 3673 Views
  • 3 replies
Canon IJ Driver Installer Has Stopped Working.
Trying to install the PIXMA MX922 on my Windows 10 Pro 64bit computer.  Disabled Kaspersky and Malwarebytes.  Whenever I try to install mp68-win-mx920-1_00-ejs.exe a window pops up that says Canon IJ Driver Installer Has Stopped Working. I've already...
jsm1963 by Contributor
  • 42767 Views
  • 14 replies
