Desktop Inkjet Printers
Resolved! PIXMA iP1600 does not print color
iP 1600 does not print color, not even a smiggeon. I rarely print color so cartridge should have ink, but nothing gets on paper.I set printer preferences to 'Color'. There is no indication that printer believes it's out of ink. I refilled BLACK cartr...
artfulm by Apprentice
  • 3621 Views
  • 2 replies
Pixma MG5250 no longer printing duplex
Hi,I have owned a Pixma MG5250 printer / scanner for quite a while now. I have used this printer with both PC and currently for the past two tears with an iMac. It has always printed duplex double sided copies, with both MS and Apple OS, fully wirele...
Canon G3200 printer
I purchased a Canon G3200 printer on Sept 1, 2017.  It failed with a printer feed problem 5 months later and was replaced by Canon.  The replacement printer has now failed 8 months after receipt,with error codes 5B00 and 5B01 (apparently an ink absor...
Using Selphy CP910 with Windows 10
Are Windows 10 drivers in the works for the Selphy CP910 or should I pack up the printer and return it to the store?  No current production model should be without drivers for the latest operating system.  Its not like I had a choice to pick Win 7 or...
SuperPat by Apprentice
  • 18448 Views
  • 12 replies
  • 1 likes
Spots on underside of glass platen of MP240
Does anyone know how to remove the glass platen on an MP240 printer/scanner? I want to clean some marks that have appeared on the underside. The manual doesn't have any instructions about doing this and it seems to be rather extreme to send it away f...
JimmyMac by Apprentice
  • 2182 Views
Canon PIXA MG3650
Just purchased Canon PIXA MG3650. Works fine, but; 30 seconds after every print operation, the printer makes a noise as if it is attempting to print again. That lasts for about 10 seconds. How can I stop that please?
BG1 by Apprentice
  • 2305 Views
PIXMA TS9120 horizontal lines,not white lines
I just bought the TS9120 recently from best-buy. I'm getting the even spacing deep color horizontal lines when I do the plain paper printing and the copying. Higher quality setting will make the spacing narrower. White paper copying (nothing on the g...
Printing on CDs, Label software settings
I purchased my Canon PIXMA TS9120 specifically for its ability to print on CDs. My label software is asking for the Canon tray type. Which do I chose? Full or Standard Face and which tray? A,B,C,D,E,F,G,H,J,L or Z?The manual only gives instructions f...
Charell by Apprentice
  • 7090 Views
  • 4 replies
Can't Install Print Driver - MX340
I have a MX340 and up until recently it was working great.  I just got a new laptop and am trying to install the printer, via WLAN. As it goes through the installation process, it will install the fax drivers, but won't install the print drivers.  I ...
er4455 by Apprentice
  • 2610 Views
  • 2 replies
Blurry text
Lately the text is blurry on my Canon MX922 printer. How do I fix that?Also, the color is always orangie colored, not true colors.
Margot1 by Apprentice
  • 2215 Views
