error messg for PIXMA MX920
received an error message "unexpected configuration problem 0x8007007e"can anyone explain. thanks
My MG6821 will not print black. I spent $80 on Canon cartridges at Target. CLI271M, CLI217BK, CLI217Y, CLI270PGBK, and CLI271C. Installed in that order. There is black ink all over the place inside of the printer. They were all installed properly (pl...
Hi - I have an MX922 that mostly works, but the black text printing quality is degraded. A nozzle check shows that all nozzles seem to be working. However, the PGBK section is blurrier in the middle of the test pattern.Color printing looks OK, and th...
Hi all, Would greatly appreciate help. Father passed away, trying to scan some physical photos to submit for the memorial, but it's not working: This old MP Navigator EX 4.1 crashes upon launching from the Canon Solution Menu EX. I've gone online to ...
Hi all I'm looking for a service/repair manual for Pixma ip8750. I have search the Internet without any luck. Now I put my hope to this forum. Thanks in advanced.With greetings fom Stockholm, Sweden
How can you get to the pickup rollers on the MG 3122 to clean or change them? I know it is easy on some models but haven't figured out how on this one. Is there a service manual for this one?
Hello. I have a DELL laptop. It has always communicated just fine with my printer. Recently I replaced the cartidges and now it will print something from a copy but it will not print anything I send from my computer. Literally nothing has changed b...
CLeaned cartridge heads. I do have low ink, but prints 1st page fine. then 2nd page runs thru blank.
When I try and print a full page 8.5x11 my printer is now printing sideways and on only 1 half the sheet. 4.25x5.5 and sideways. Why is this happening and how do I change it. I have set at 100 percent and full page. Only prints 1/2 sideways
I've owned the TS9120 for a few months now, and after about a month it started reporting paper jams, that turn out to almost always be false errors. I thought it was related to the double-sided printing at first, but the single page prints (even it i...
I have a Canon pixma MX432 and seem to be having so many problems recently. With new black ink in place it did print today but it is so blurry and not readable.Any ideas?
Since we started using our new windows 10 computer we can no longer scan a document without seeing the message set the pc to start scanning, how can I fix this?
My MX922 has lost its mind. When helping my daughter print something from Google Docs, we found using the high quality print setting was still returning a bad result. I ran the nozzle test and it seems to be missing the pattern at the top. I then ...
Does anyone know how to fix this problem. I deleted the app and reinstalled it. Same message.
The printer requsted to update. I agreed and now I have a blank screnn and a flashing power button light. If I unplug, it begins the update and then say "failed update press start button to try again"
| Subject | Author | Posted |
| 09-05-2026 10:28 AM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
