Desktop Inkjet Printers
MX920 vertical line alignment
My MX920 blurs both text output and copies in the same way.  Below is a picture of a copy of a standard 4-per-inch graph paper. Auto Head Alignment failed several times, then pulling the power, waiting/pressing the on button, then re-power and starti...
Canon Pixma MX925 Scanner Problem
Hello Everyone I have used the scanner many times before with my laptop and had no issues. When I set the scanner away using my laptop the paper does feed through the printer and is left in the tray. Once scanning has completed on the laptop it allow...
Graham56 by Apprentice
  • 2133 Views
Resolved! MG 7720 CD function won't make CD
Hello, I recently had a problem with the MG 7720 CD tray. I've recently updated my computer to Mac OS High Sierra (version 10.13) and the printer does work fine, but when I try to print CD's with it. The CD's print, but it doesn't print a label out. ...
Resolved! Canon Pixma MX700 - several error codes
My Canon MX700 printer is rapidly failing, having been in perfect working order two days ago. Can anyone suggest what might be wrong, and how to fix it? It's a few years old, but has only ever had to cope with light workloads. Two days ago I began en...
pmspinks by Apprentice
  • 4769 Views
  • 2 replies
Resolved! MX860 Driver with macOS 10.14.5
Need a driver for my MX 860 Multifunction Printer for macOS 10.14.5 but all sources indicate no such exists.  Canon site says this OS is not supported for this printer.  Am I out of luck?  -Bill
Canon TR8520- Issues with DRPD mode
I've been helping a friend set up their TR8520 printer after their MX922 broke down. I've bene having trouble setting up the fax so that it behaves like it did on the MX922. I wasn't able to check the settings on the MX922, but they told me that they...
Canon Pixma MG3600 won't print?
oonly had this printer for a couple of weeks, since converting to Windows 10 from 7.It worked for a couple of sessions, but will not now?I have tried "troubleshoot" in win 10, but nothing found.Can anyone offer some advice please?
bobmax by Contributor
  • 12586 Views
  • 13 replies
Resolved! Pixma G6020 Setup
Just got my new printer.  The manual says to fill the ink tank with all six bottles.  Three black ink bottles come with the device BUT it filled with only 1 1/2 bottles.  Is this right?  jim
JimWilly by Apprentice
  • 3186 Views
  • 2 replies
MX700 Does Not Do Black and White Copy
MX700 goes thru the motions of printing...noises and such.......but produces a blank page when.  Pressing the Copy/Black buttons.   Pressing the Copy/Color buttons produces an image.  There is no indication that the Black Ink supply is low from the 4...
kaneohe by Contributor
  • 7974 Views
  • 8 replies
Pixma MG5420 won't power on
Hi,I've read the directons on how to reset by unplugging for a while and then plugging in directly to an outlet. Does anyone have any other suggestions?This printer has been working perfectly with light use for 5 years. Is it just time to junk it? It...
JACKSML by Apprentice
  • 2282 Views
