Pixma ts9020 Will not print color
3 year old ts9020 will not print color. B & W is fine. Installed new print head, cleaned nozzles, downloaded new drivers, nothing works. Any ideas
Hello it seems there re no drivers available for my operating system, MacOS Mojave v10.14. Are there any other options or ways around this?
Please help me get this mx492 working again! It was working fine, but my wifi ISP wasn't. I was offline for about a month, no need to print/scan. Got new ISP. Couldn't connect. Bought cord. Connected. Tried to print.....errors. ...changed to new cart...
Printer Model TR8520 stopped printing in black and white. Have done deep cleaning, nozzle alignment, etc. Settings on Business Document, print quality is set to high, print set to Grayscale. Print comes out reddish. Test page prints okay, SELPHY ...
I have a new canon 452 and get support code 1250 both from my macbook as well as from my iphone 5. Appreciate any help
Paper doesnt go in the printers back feed. right back corner grabs but then stops trying to feed paper through. thank you for help!
Hi! I had a problem with the black not printing this morning - ran a nozzle head clean and that sorted it. Then realised that the magenta wasn't printing either. Have since done a deep clean and nothing. The ink level is just above the halfway li...
Printer was working fine until the last time I turned it on. Now it's giving me an error code UO52 saying it can't recognize either print cartridge. Replaced both, but still getting same error. Unit will not work for any Print/Scan/Copy function. ...
Hello, i have the Canon TS5120 and all my photos are printing letter size. I am printing from my iPhone and it does not let me select 4x6. I’ve read about registering the paper for the back try but apparently it’s set on letter and I’ve followed all ...
MacBook Pro running High Sierra. TS6220 keeps dropping wireless connection. I open a file, send it to the printer, and can see that it's in the queue, and then the printer says "printer is not connected." Occasionally turning wifi on & off will reboo...
I have a TR8520 I purchased this spring and print only black and white by selecting "grayscale", but all of my color ink cartridges are almost empty. What am I missing??
I'm trying to set up my daughter's TR7520 for use in a college dorm. Everything works fine wirelessly, but she will not be able to connect the printer to the wireless network in her dorm. I can print from the computer using a USB cord, but I am una...
Have a Pixma 2500. When I print, the printer seems to print but the pages come out blank. I checked the ink levels and they are not empty. What else could be wrong? The problem first occurred and then it printed ok when I tried again, only the bottom...
My Canon TR8520 is printing, scanning, and copying in color even though all settings are Black and White. Too make it worse the colors being printed do not match the original document. Have tried all maintenance items including the deep cleaning, n...
All of a sudden, my G5020 is printing purple instead of black. It's been working absolutely ok and printing actual black up until now, but today, in the middle of a sheet, it started printing purple instead of black. I'm printing out the nozzle-check...
| Subject | Author | Posted |
| 09-21-2026 01:06 PM | ||
| 09-20-2026 05:36 PM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM |
