Desktop Inkjet Printers
IX6800 WON'T PRINT FULL IMAGE
My printer keeps leaving half of the image out whenever I try to print. Yes, I have the paper size set to the same on both the printer and my computer. I've tried unplugging it and plugging it back in. I've restarted my computer. I've even tested the...
Print Issue
MG3600 alignment page getting stuck
My MG3600 prints crooked lines.  Have tried the method of holding the stop button until error button flashes 4 X, which starts the printing of an alignment page.  However, the alignment page continues to get stuck 1/3 of the way through. I then have ...
rra_78 by Contributor
  • 3886 Views
MP530 issue
When I turn on my Canon MP530, the orange alarm light blinks 12 times. An error code on the display shows 6A00. When the printer cover is opened, the print head does not move to the left side. I really need help with this.
Zorroxxx by Apprentice
  • 1286 Views
PIXMA TS8222
My printer won't leave the canon start up screen. It was plugged in and unused for a while, and then I unplugged it and packed it for about a month before I moved. I went to start up the printer after I moved and it just won't leave the start up scre...
MG 8120 will not print envelopes anymore.
Hello Community.  I have a MG8120B that I've been using for a number of years now.  Great little machine that prints beautifully.  Trouble is, it recently stopped printing out envelopes. I put the envelope to the rear tray and access the mailing sect...
acsd235 by Apprentice
  • 1389 Views
Can't get MX922 printer to communicate with my PC
After my Windows 10 desktop PC was rebuilt by Best Buy my Canon MX922 printer won't communicate with PC.  I have installed latest driver.  when I go to Menu / Setup / Device Settings / LAN Settings/ confirm wired LAN Active / LAN Setting List Connect...
Canon pixma mx492 standard encoder
I have a canon pixma mx492 printer, A child took out a plastic strip with a spring on one side and on the other side it says standard encoder. I can not find anything on how to put the encoder back in place, only how to clean it. When I start the pri...
MXP by Apprentice
  • 1486 Views
TR8520 shuts off and won't power back on
Hi,My TR8520 started doing this last week. It shuts off, and will not respond to the power button or anything other than unplugging it for 30 seconds or so and plugging it back in. I had turned on the setting to wake itself when a print job appears, ...
Pars by Apprentice
  • 2388 Views
MG3620 Drivers won't download, cannot scan
Hello. My MG3620 has remained my possession with the single highest use-to-issue ratio. The number of times I have needed to use it is almost exact to the number of times I have had to come to this board for help in order to successfully do so. Alway...
Pixma Mini320
Hello. I have a pristine Pixma Mini320 that I would like to use. I have a new MacBook Pro and they don't seem to be compatible, so I tried to transfer photos from the Mac to an SD Card, which should allow me to print. No luck. The trouble I'm having ...
KJ430 by Apprentice
  • 1436 Views
