Laptop Not Finding PIXMA MP280
My new laptop is not finding my MP280. It says 'driver is not available'. Is there any way around this, or do I just need to buy a new printer...?
On my MG7550 printer all black vertical lines (e.g. when I try to print barcodes) appear as slightly offset lines, not continuous. Every 5mm or so the line is offset about 1mm to the left and then to the right. It only happens with black. Other color...
I have followed all instructions to resolve error coded 1303 and the printer still shows the same error after multiple attempts and following your instructions to resolve the problem. Is there a workshop in my area to get immediate help?
I've done multiple deep cleanings and regular cleanings and still the print test page comes out like this. Is there any way to clean a print head myself, using isopropyl alcohol or something?
Moved printer to a different room; when I turn it on cartridges now make a clicking sound as they try unsuccessfully to advance from left side to center. Error code 5100 but there is no paper jam that I can see.
When trying to print from PC, Mac or iPhone, G6020 wants to use rear paper tray, despite the fact that I chose main cassette (was on Auto) for paper feed. Also specified cassette in print dialogue boxes. Considering throwing printer through window.
My Canon G2020 Printer keeps scanning a single article (item) into several pages. How do I fix this?
I have had Word for years and always been able to fax from it thru the multi functoin printer/fax machine I had at the time. Not so with the MX922 and Word 2010 combo. How it usually works is that you just click 'print' but hen select the "MX922 FAX...
Hello! I have removed the drivers fully once before from my computer and reinstalled but for some reason my printer ejects all the paper that it has loaded into the back, says there is no paper, then I put back the paper and then press the button to ...
I'm not sure this is relative, but my ink ran out. I replaced the ink, but accidentally had the wrong color in the magenta spot. The code 1259 came up. I have since placed the magenta in its correct spot. My paper tray does not have a stop when I pu...
Edible images printerI have a cannon TR8620a and I can not get the blue ink to print, any suggestions on how to get it to work! Thank you
I have a Pixma MX860 running on Windows 11 home, ver 22H2, with 64-bit processing system. It has provided good service and prints, copies, etc. just fine. But now, when I try scanning this message appears: "An error has occurred in the scanner driv...
Hello;I have owned my Canon iP8720 printer for 4 years now. It has ALWAYS printed well. I have printed maybe 250 photos from 4x6 up to 12.95x26.6" long paper size. The only reason I give it only 4 /5 stars is the printing software and UI. The ...
My Canon PIXMA MX452 will not print in color. When I select something to print, it shows in color on the computer screen printer menu, but always prints in black and white.I have deep cleaned the heads 3 times. I did a nozzle check.The nozzle check p...
Hello. As noted in my message title, I am suddenly getting the infamous B203 error on my Canon Pixma 7720 printer. Before now, the printer worked just fine. I am currently using an iMac (Retina 5K, 27-inch, 2019) running. Ventura.13.3.1From searching...
| Subject | Author | Posted |
| 09-23-2026 07:16 PM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
