Desktop Inkjet Printers
PIXMA MG2522 Paper Jam Error
Hi, I have recently purchased a PIXMA MG2522 printer. It was working this morning, but then it suddenly got a mysterious paper jam! There is no paper in the printer and I have not been able to figure out what may be causing this ghost paper jam. Rein...
PIXMA TS8320 locks up when powering off
My printer is 2 years old and I recently switched it from using USB to WiFi. Now, when the printer tries to power off, it locks up and won't respond at all, requiring it to be unplugged. Even after waiting overnight, it still won't power down. This a...
LloydGM by Apprentice
  • 2111 Views
  • 3 replies
Printer Pixma MG2522- Paper Jam Error
I keep getting an error message that I have paper jam. There is no paper in the printer. I've attempted in turning off the printer, unplugging the printer, etc. but I continue to get a paper jam error. Any suggestions?
JC81 by Apprentice
  • 12061 Views
  • 8 replies
  • 2 likes
Resolved! Canon MG2522 with bank checks
I want to print on standard pre-printed bank checks but the MG2522 adjustable paper guide does not move far enough to the right to properly guide the checks (2.75 inch wide). Because of the gap, the checks turn slightly while feeding. Is there a work...
jf92647 by Apprentice
  • 2173 Views
  • 2 replies
TS9120 Just started cutting off bottom of page
This is only happening when printing.  Scanning is fine.The bottom inch of the page is consistently cut off when I print on my TS9120, regardless of the application from which I am printing. This problem emerged suddenly-- the printer had worked OK p...
scottdm by Apprentice
  • 2473 Views
  • 5 replies
MG2522 Jammed but no paper in printer
Not sure if this is the correct place...I am trying to print out an important report for work and my printer keeps saying it is jammed, though there is no paper in the tray. I have tried messing with the placement of the printer on my computer (switc...
NyxCora by Apprentice
  • 6137 Views
PIXMA MX925 Error Code B200
Hi, I'm having an issues with my Pixma for a long time but recently it shows some B200 Error codes and today won't turn on. I tried to unplug it and push the power button 5 times and plug it back after 60 sec as advised in another post, I've also tri...
Maryan by Apprentice
  • 1614 Views
  • 0 replies
Canon IJ Scan Utility Error Code 9,230,0
Hello my name is candra.i have a problem with my Canon IJ Scan Utility eror. the problem is cannot use again and opened eror code 9,230,0 (a Scanner driver supporting this software is not installed instal it and try again)After i uninstalled Canon IJ...
candra by Apprentice
  • 19318 Views
  • 8 replies
  • 2 likes
