Can anyone explain... PIXMA TS3352 displaying 0
Don't understand what this means on my ts3352 printer.
Just bought this from Best Buy because it says it can print up to 74lb paper in the rear tray. I have to guide each page to print by lightly pushing down on it. It's not feeding the paper. I had a similar issue with an IP8720 I had to return. This is...
I have previously posted that my Pixma MX922 would not power up. I tried all of the suggestions that I got about holding the power button down for 30 seconds and then unplugging the unit. Nothing worked. I purchased a new power unit and it would p...
I recently purchased a printer and find that it calls for CLI 281 cartridges. Yet, when I go to a retail store, all the PIXMA cartridges are 251. What is the difference?
Hello! I have a problem with my printer, when I set printing to automatic duplex, sometimes it prints normally, but most of the times the printer reports a 1310 error "The size of paper may not be compatible with automatic duplex printing." However, ...
Ok, so I have brand new ink jets installed, lots of paper and am all hooked up with my Chromebook. I go to print and the paper goes through, slower than usual and there is no printing on the paper! What is going on and how do I fix it?
Last week my G3270 started telling me it was no longer available in the middle of a print job & now I have my TR4720 doing the same thing. I run both through the Print app on my iPad Air 5th generation. The firmware was just updated so it’s not an ol...
Will the TS3500 print on transparency? I was repeatedly getting an error saying that the printing settings needed to be changed...
Hi. My Canon Pixma TS207 keeps on skipping 1 inch line horizontally. During nozzle checks, only half of the black is printed. Also, when printing images, black seems to be out of the print, but when I print documents sometimes it works well. Although...
Does anyone know if you can put 2 different size cartridges in the printer? Example: PG-285 and CL-286XL or PG-285XL and CL-286. Thanks...
Hi...I just purchased a Canon PIXMA TR7820 printer. I changed the feed tray from cassette to rear feed to print a photo, and now cannot figure out how to set it back to cassette feed. Would appreciate instructions on how to do that. Thanks!
I have a Pixma MX475, when ever i try to print borderless it's blurry/misaligned.I've run all the cleaning and aligning options multiple times,it prints PERFECTLY when not printing borderless,but fails miserably every time i try to print borderless.H...
Hello I'm having a lot of trouble figuring out the print settings with the screen I have for my printer. The colors are not right and with borderless printing, the images are getting cut off at the bottom of the page. I would appreciate some assistan...
I know Canon printers are commonly used with edible ink to print edible images; I use TS702a myself for this purpose. I was previously told as long as it is a new printer, you can install the edible ink and start printing. But others say even new pri...
Hello: I just purchased my first Canon printer and I like it before than my previous not-a-Canon printer. I have one issue: How to I set things up so that I can print Avery 5163 (4" wide x 2" tall) mailings labels? When I go to Print and under Settin...
| Subject | Author | Posted |
| 09-23-2026 07:16 PM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
