pixma ip5300 windows 8 driver
Could you tell me how could I make working/install my Canon Pixma ip5300 inkjet printer on my Windows 8 laptop? Thank you George, Athens,Greece
When I go to system preferences and try to check under printers and scanners info I check under settings and I keep getting a message no information available.
Unable to scan from printer to pc
Help! PLS.. I am using windows 7. the printer dsnt work in my laptop (sony vaio) but its working in my husbands laptop (Asus) same OS. When i click print it will show the SEND FAX box.I install the printer twice already I did the first one and then ...
I tried everything suggested online to get rid of this error message B200 and nothing is working. I can't believe this printer is useless already..what else can i do besides turning it off and on, cleaning the printer contacts..and praying something ...
first time I tried printing on 13x19 photopaper and it gets stuck on the way in. one side pulls the paper faster than the other. I tried cleaning the roller, checking for foreign objects, nothing. I am trying to feed one sheet at a time. any ide...
Is it possible to print irregularly sized pictures on the Pixma MG5220, i.e. sizes that are not manufacturer preset, like 4"x4", 8 1/2"x 11", etc? Thus far the only work around I have found is to copy and paste the image into PowerPoint, adjust the s...
Have Pixma iP 100 installed on Toshiba A665 laptop. Was working fine. Then upgraded to Windows-8 after which computer failed to recognize printer. Have down loaded Wx 8 driver from Canon website to no avail. Have uninstalled and re-installed still to...
I just bought a new canon multi purpose printer I have nearly installed but the message comes up as set the ink jets and can replace the cartledge . what does this mean and can I fix it?
I cannot get my printer to work wirelessly, it is a pixma mx410. Mp driver error message during installation.
Just brought home a new canon printer and am getting frustrated. It will not connect to our dell laptop.
I have a MG5330 printier. It is not printing blue. I have done all the maintenance. It may print one sheet and then the blue stops printing.
Hello , the ip4900 uses some defaults timeout settings for auto power base on a quarter of time (15, 30.... min). I was wondering if there is any way to change these setting in custome, like 2 or 5 minutes. thanks
Does anyone know if the Canon MG8120 has built in OCR? If so, how do I find out how to use it after scanning?
| Subject | Author | Posted |
| 09-05-2026 10:28 AM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
