05-28-2022 05:27 PM
Canon Pixma MX490 powers on and goes through initialization, then powers back off. Keeps repeating the process as long as it's plugged in. Buttons are non-responsive.
06-03-2022 05:52 PM - last edited on 06-07-2022 02:03 PM by Danny
Your satisfaction is important to us, and we apologize for any inconvenience you may be experiencing. A firmware update is available to fully resolve this issue. You can download the firmware update and find easy installation instructions at canon.us/power.
05-31-2022 11:13 PM
Yes like I have no idea what any of that means
05-31-2022 10:51 PM
Almost midnight and printer is still not working. Beyond upset, it’s clearly not the machine itself fault if we are all having the same issue. Printer has been working fine for years and was working just a few days ago. Very upsetting that canon refuses to fix this problem and just tell us to “buy a new printer” when this is something fixable. Not only do the machine themselves work but this contributes to the ever growing electric waste. In our culture the first solution to our problems shouldn’t be to just buy a new machine, especially when the problem seems to be an easy fix on canons end. If canon does not fix this problem I definitely know what brand I won’t be buying.
05-31-2022 10:56 PM
05-31-2022 11:14 PM
I have no idea how to do that though
05-31-2022 11:29 PM
Having same issue. Glad to see I'm in good company, but frustrated that there's still not a fix from Canon. Just ordered 2 new cartridges. Looks like I'll be returning them and getting a new non-Canon printer if this isn't resolved shortly.
06-01-2022 12:46 AM
when the Wi-fi is off then it powers on and goes through - but did not have success with the usb connection either
06-01-2022 12:49 AM
Well i had that issue 3 days ago - tuned it off thinking the printer was busted - it printed out stuff once and went back to the stupid poser cycle over and over again - it seems its a firmware issue - gonna see if it will work via usb - just got new inks - this is so stupid
06-01-2022 01:08 AM
the Printer works fine on USB connection - hooked up straight to the computer - the wirelesses part of the Firmware is screwed up it seems - been using the printer for few years and it was fine - always hooked up to Wi-fi, my kid needed to print paper for his homework and the printer started power-cycling again - looked at the posts above and disabled the wirelesses downloaded the original drivers installed - and hooked up via usb and it works - BUT as soon as the Wi-FI is back on it goes all crazy again - is there a way to reset the wi-fi connection ? or disable ? don't want to buy another printer after spending so much on 2 sets of brand new XL inks
06-01-2022 06:45 AM
My MB2050 is experiencing the same issue. It is stuck in a loop, turning off and then turning back on.
06-01-2022 08:52 AM - edited 06-01-2022 08:52 AM
Registered just to add my name to the list 🙄 MX492 here. Same issues. Canon needs to figure this out..
