01-05-2024
02:28 PM
02:31 PM
Just got a Pixma TR8620a and have same problem with power cord. If I look at it the wrong way, it falls out. Incredibly poor product design by Canon.
01-09-2024 09:59 AM
Based on this type of issue, I recommend you reach out to Canon support. Our team will be able to assist you in real time with this matter. You will need to register your Canon gear HERE to access additional support options.
We look forward to hearing from you
01-09-2024 09:59 AM
05-05-2025 07:24 PM
Same problem here with an MG3600. Incredibly loose connection, falls out every time I move the printer even a fraction - is there something like an additional sleeve or silicone support that would make it not fall out please, or can someone invent one?
05-17-2025 03:18 PM
I have the same problem with my TR8650a. Were you able to get help.
05-17-2025 03:24 PM
Hello!
So that the Community can help you better, we will need to know more information.
What is the exact model printer you're using (it's usually on the top or front of the unit)?
Any other details you'd like to give will only help the Community better understand your issue.
If you're in the United States, and this is an urgent support need, please click HERE to visit your My Canon Account to discover your personalized support options.
If you're outside the USA, please click HERE to find support options in your country.
Thanks and have a great day!
05-17-2025 03:34 PM
TR8620a. The power cord falls out of the receptacle on the back of the printer at the drop of a hat. This is the second printer of this model I have owned and the same thing happens on both. I guess I should have learned my lesson and bought something else
05-17-2025 03:47 PM
Thank you Arthur, but when I go to that link and try to register my product it says my serial # is not right. But it is. This is very frustrating.
05-20-2025 04:09 PM
Hi lizscher,
Please turn your PIXMA TR8620a on and then from the Home screen, please tap the info.jpg icon in the lower right hand corner of your printer's display.
In the menu that appears, please tap "System information".
The serial number of your PIXMA TR8620a will be listed on the third line from the top.
If that is the serial number that you had tried previously, please reply to my post with the 4 letters at the beginning of your printer's serial number.
