PIXMA MX922 How to scan to a USB drive
timevans7057540
I have a Pixma MX922 and I am trying to scan to a USB drive. When I plug the USB flash drive into the printer, the printer says "USB drive detected".  So I set up the Scan to USB flash drive function.  But when I scan I receive an error message "Cannot detect a USB flash drive". Doesn't matter if I scan from the feeder or the screen.
Any suggestions?
I have a SanDisk 64GB from several years ago.  It appears to correspond most closely to this one on SanDisk's web site:
https://www.sandisk.com/home/usb-flash/cruzer-glide
I also have a MicroCenter 128GB that you can find here:
http://www.microcenter.com/product/486104/128GB_SuperSpeed_USB_30_Flash_Drive
Good luck.
17 REPLIES 17
BillS
Mentor
Hi timevans7057540,
I'm afraid the port on the front of the MX922 is not a USB port, but is meant for printing from PictBridge enabled cameras.  A USB drive will fit, but will not be recognized as a destination.  I regret any inconvenience.
This didn't answer your question or issue? Please call or email us at one of the methods on the Contact Us page for further assistance.
Well, perhaps BillS is not the product expert he thought he was.  (Sorry, Bill, but try not to be afraid about the machine.)  The port on the front is a USB port and will accept scans.  That said, the printer is **bleep** particular about USB drives; it will not recognize many of them, but it does recognize some.  I've been scanning to USBs on my 922 for some years now.
Thanks for the reply.  Any advice on which type of USB drives to use?
Good luck.
I bought the MicroCenter USB and it works like a charm in the front USB port. Now I can scan easily. Thank you so much!!!
RidleyNY
I have a Pixma MX922 and use the Canon IJ Scan Utility for scanning to my Mac. I don't have problems scanning the first document.  After I choose 'Exit' to save the scan and want to scan another document, the app becomes unresponsive.  I have to quit out of it and then re-open to scan the next document.  I've tried to download recent & recommended drivers but it hasn't helped.  Anyone else had this issue and find a solution?  Thanks.
Hi RidleyNY.
That problem sounds like an issue that occurred for some users when OS 10.15 first launched.  Try the following:
  1. Open Finder and navigate to Applications >> Canon Utilities.
  2. Drag the IJ Scan Utility folder to the trash.
  3. Navigate to Mac HD >> Library >> Image Capture >> TWAIN Data Sources.
  4. Drag the MX920 series entry to the trash.
  5. Download and reinstall the MX920 seriers Scanner Driver from the MX922 Drivers & Downloads page.  The Scanner Driver installation comes with the updated version of the IJ Scan Utility.
Worked great!  Thanks!
To WTig3ner: Seeing your encouraging post, I went through eight USB drives and the printer would scan to none of them (even after saying "a USB drive is connected")! Last resort: tried a USB card reader -- same shape as a thumb drive, but with side slots for SDXC and MicroSD cards. Plugged in a Kingston 16G MicroSD card, and it worked perfectly. It was so much easier to use the document feeder on the 922 than page-at-a-time scans with my flatbed scanner. Thanks for correcting the erroneous info from BillS -- after his entry, I almost clicked away without reading any further!
Holiday
EOS C400 - Version 1.0.4.1
EOS C80 - Version 1.0.4.1
XF605 - Version 1.0.7.1
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
