05-27-2014 09:15 PM
I had some problems and had to reinstall my MX922 on my Windows 7 Pro (64-bit) computer. I used an Ethernet cable during installation but then switched over to wireless. But Canon IJ Scanner Selector is still showing the MAC address for the wired LAN port on the MX922 so it reports that the scanner is not connected and I can't scan anything. How can I get IJ Scanner Selector to use the correct MAC address for the wireless LAN port?
05-27-2014 09:33 PM
I figured it out. I reinstalled the MP drivers (again!) and that fixed it. IJ Scanner Selector now has both wired and wireless MAC addresses for the scanner so all I have to do is to make sure I select the correct one.
05-27-2014 09:33 PM
05-24-2018 02:24 PM
I cannot scan and my MX922 has alway been installed as wireless. So how do I get the scan to work? Otherwise this printer is useless. Running windows 10.
05-25-2018 04:24 PM
Hi bbrody,
Scanning represents a fairly large transfer of data, so let's start by checking the printer's connection to the network.
to select
Setup, then press OK.
Device settings, then press OK.
to select LAN settings, then press OK.
to select Confirm LAN settings, then press OK.
to select Print LAN details, then press OK.
to select Yes, then press OK to start printing.Much of the information will not be relevant, but the important things to look at are:
Is the connection active or inactive?
Does the SSID (network name) match the one the computer uses?
What is the signal strength?
What is the IPv4 IP address?
I look forward to your reply.
04-23-2020 06:45 PM
My Canon mx922 prints but won't scan.
Network configuration page
Connection: Active
SSID matches my computer/laptop
Signal Stregth 73%
Ipv4 IP address 192.168.1.2
What else do I need to do to get the scanner working?
05-06-2020 03:00 PM
Hi nolimitt168,
What version of Windows are you using? If you are using a Mac, what version of OS X is installed on your computer?
06-02-2020 05:23 PM
I'm having the same difficulty:
Connection: Active
SSID matches
Signal Strength: 68%
IPv4 IP Address 10.0.0.40
I am on a MacBook Pro with Catalina 10.15.5
06-03-2020 09:05 AM
Hi ChattyKathy,
You signal strength is a little low for scanning. Canon recommend 80% or higher for scanning. If the printer is far from the router, you can try moving it a little closer.
If the printer and router are close, you can try resetting your wifi. First, turn the printer off and then go to your router and unplug the power cord to it and let it sit for 10 seconds. Then you will want to plug the power cord back in and let you network start back up.
Once the network is up and running, turn the printer on and print the network settings again. Is the signal strength still 68%?
