05-28-2014 12:16 PM
Hi - I hope someone can help me.
I've a well-established Pixma MG5250 and I've been using a wifi connection to print and to scan successfully. Something's happened - maybe I inadvertently deleted an important file - but the scanner no longer works. When I try running Navigator it gives me the "Cannot start the MP Navigator EX. Check the following points......" message. When I look on the printer itself, it seems to think that the scanner is connected by USB rather than wifi.
I've tried all the suggestions I've found including
Uninstalloing everything and reinstalling
Deleting all network shortcuts
Checking the Twain 32 folder
Temporarily disabling Windows Firewall
Any thoughts?
05-28-2014 09:33 PM
few of my friend did encounter the same problem and all of them using Windows 7 32bit. But even myself are using the same OS but havent encounter this problem yet so far. however, i did heard that the causes to this problem is from Windows itself. Some of them said that after did the Windows update this problem will occur whereby you cant perform scanning. we have done exactly as the steps you do but end up nothing happen.
Appreciate if anyone here could feedback if you are encountering the same issue on your laser printer or inkjet printer.
03-12-2015 02:10 PM
I own a MG7520 that is doing the same thing " the scanner stop working for no reason" I have updated Drivers and software to latest version with no change. My OS is XP service pack 3. Any body has any idea what is causing this to happen?
03-16-2015 02:37 AM
Hi kenn,
Do you have the printer connected wirelessly or via USB cable?
If this is a time-sensitive matter, additional support options are available at Contact Us.
