Resolved! Blurry print out
Have a MG3620. Ran all the cleaning ana alignment deals and when I print a document the letters are too blurry to read
Color prints fine. But B&W won't print anything but a blank page. Have tried two new cartridges, multiple cleanings and deep cleanings, one manual cleaning of contacts, and a complete power off and unplug. Still nothing but a blank page. Help?
I just installed a Canon Pixma TS 9120 printer. When I reboot or cold boot without manually shutting down my printer using it's power button, it gives an error. Is there a way to stop that behavior? I had no such problem with other printers. I am run...
When I try to preview a document I'm about to scan, the scanner freezes and grays out all options and doesn't show the preview image. I have to force quit the app and start over. It will scan the image if I just skip the preview. On the printer itsel...
Hi - my printer has a full black ink cartridge, recently replaced, but it prints as if it doesn't have any black ink - so it's using the other colours to try and print black, which is incredibly wasteful and means what is grey turns out as an oragey ...
I have a Canon TR7520 Muti - function Printer.The specs say that the max print resolution possible is 4800 x 1200 DPI.Does anyone here know how to access this resolution? I have looked around and haven't found anything on the subject. Thanks, TR7520
I downloaded Sure Thing disk labeler and there is no manufacturer listed under the settings when I open it. The tray Canon provides is only one disk whereas default on the Sure Thing is two and so I cant print. Is there a downloadable template I can ...
I purchased a pixma G3000 series printer and installed it on my macbook pro OS 10.14.3 (Mojave) When I switch off either the computer or the printer and switch on again I jave to reinstall the printer to be able to print, even though the printer may...
Printer - MX922; MAC OS Mojave. Following cancellation of Adobe free trial, some (not all) pdf files began to print tiny rectangles or other gibberish. No problem before. Tried updating driver, cleaning, resetting print quality, every plausible thing...
This is my fifth request for help!! I am about to give up, throw my printer in the trash & never again purchase anything Canon!!!I desperately need help!!!I am deaf & cannot use a phone. **Email address removed per forum rules** Please help me with e...
We got a new computer. I set up our printer (canon pixma 495) wirelessly with the computer. When I try to print nothing happens though. The computer says it's printing and the display looks like the printer is receiving data as the light goes around ...
The front tray is loaded and when I try to print it tells me that there is no paper in the rear tray. I don't want to print from the rear tray. I never use the rear tray although it will work.
How do I access the bottom of the scanner glass for cleaning. I have a brown haze in the ADF scan area on the underside that is showing up as a background fuzzy stripe on all of my docs going through the ADF. It is not on top, I have already cleane...
I have a brown haze in the ADF scan area on my MX882 that is causing tan lines on fed documents and faxes. The haze is on the underside of the glass. Anybody know of a way to access this area for cleaning?
Hi, I replaced my current printer with the Canon TS5151. In the manual it says that it can scan from ADF (multible pages at one), however I noticed that scanning it's only possible with the flatbet option. Can someone help? Is it possible to scan fro...
| Subject | Author | Posted |
| 09-18-2026 11:59 PM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
