11-12-2017 06:52 PM
OS: Windows 7 x64
My system had been working with an existing MX922 using Wifi print/scan until couple weeks ago when I bought a new MX922. I connected the new MX922, tried to print a few pages and realized I would need to uninstall and reinstall the MP driver since I had to do this same process for other PCs in the house earlier. I opened up the print queue, cancelled the print job, uninstalled the MP driver, reinstalled the MP driver (lastest from Canon website) but now the printer does not work anymore using either Wifi or even USB cable, the scanner seems to work fine when I start a scan job from the PC.
I even tried turning off the printer, PC and the router, wait a few minutes and turned everything back on, no joy !
When I run the Canon Network Tool I get an error "There are ports that cannot be used with their current settings...", the network tool also displays
Name Status Model Port name
No Driver Found Canon MX920 series CNBJNP_mac address
I have installed the driver many times before on several PCs in the house and this is the first time this has happened, there's probably something different about this particular PC but I have no idea what and the PC used to work fine with the old MX922.
The following is the log when running the driver setup program:
Setup Results
Model :
Canon MX920 series
Network Setup of the Printer :
Failed
Name :
Port Name :
CNBJNP_00BBC1B6D610
Network Setup of the Scanner :
Completed
Name :
Canon MX920 series(00.BB.C1.B6.D6.10)
Network Setup of the Fax :
Failed
Name :
Port Name :
CNBJNPFAX_00BBC1B6D610
Network Type :
Infrastructure
SSID :
MyRouter
PLEASE HELP ! I have spent close to 8 hours troubleshooting this to no avail.
01-16-2018 04:13 PM
Hello.
Troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
