06-25-2016 01:23 PM
Called Canon Support and they say it's unrepairable but past 1 year so unreplaceable too. Tried everything including dismantling the printhead assembly to manually clean. Barely used the printer, 1 or 2 prints a month.
Anyone have recommendation on non-Canon I can buy to replace for around the same price range?
07-25-2019 11:16 AM - edited 07-25-2019 11:21 AM
I had to do this twice, but for now your solution works. FYI, my problem started with a paper jam. Thank you for posting your solution.
I have chosen Canon over HP for my last 4 printers (over the last 2 decades) because of their robust paper-handling capabilities , i.e., printing on heavy stock without jamming, and I'm sorry to see so many folks who are unhappy with Canon products as a result of this error. My current MG7520 is about 4 years old.
10-17-2019 10:22 PM
Didn't work for me. I was printing today with no problems. When I went to print my last page, I got this error. Tried everything suggested. Called Canon who told me I needed a new printer. Of course, I'd just ordered & received a whole set of new ink cartridges a few days ago.
01-10-2020 10:48 AM
Thank you for your solution. i've been doing it sucessfully for about 3 months now, but the problem seems to be happening more frequently. I guess I'm going to start looking for a new printer. I've been loyal to Canon for the last dozen years or so, but....
01-22-2020 12:13 PM
I have used this workaround successfully a few times, But today, although it seems to return the printer to working condition, a few seconds leter the error recurs. I suspect that each cycke I go through to "fix" it also wastes a bunch of ink. So I'm off to buy a new printer.
05-15-2020 03:56 PM
"turn off machine, Open the printer like you will be inserting ink cartridges, turn on printer, when the cartridge/printhead unit starts to move, close the printer. When I did it it did a self check for 3 to 4 minutes and when it was done it was ready to print."
This advice totally worked for me. I had no idea what "did a self check for 3 to 4 minutes" meant, I just left the printer open for that long. It seems to be working fine now. Hopefully the fix will last.
10-14-2021 02:54 PM
worked for me (thus far!)
08-07-2019 10:41 PM
Hi, I experimented the same issue yesterday when I was using the Canon application for Android phones. This issue usually comes out because of the printing order stays in the queue. So no matter how many times you reboot your printer, the fact is you needing to clean that queue, so my advice for you is to reboot the device from where you sent the order!!! Good Luck!
08-08-2019 08:30 AM
07-31-2020 08:58 PM
What method. I don't see it. Thx
12-21-2018 12:49 AM
same here, canon is dying , no more Canon
