06-25-2016 01:23 PM
Called Canon Support and they say it's unrepairable but past 1 year so unreplaceable too. Tried everything including dismantling the printhead assembly to manually clean. Barely used the printer, 1 or 2 prints a month.
Anyone have recommendation on non-Canon I can buy to replace for around the same price range?
12-21-2018 12:49 AM
same here, canon is dying , no more Canon
01-03-2019 01:32 PM
My 3-year old MG7520 spit out the B203 Code today. It's a great printer and I hate to lose it. Removed the print head and cleaned it. No luck. Called support and they were of no help (told me I had corrupt drivers). Tried the Machine Off - Lid Open - Machine On - Close Lid method. Wow, it worked for me . Like others who have posted, there is no telling how long the fix will work. But for now I am printing. Agree that Canon ought to put this fix out there for all those frustrated by the dreaded B203 Error Code.
01-13-2019 02:48 AM
My printer is MG 7760.
Had increasing trouble with the clarity of print so after trying everything else I removed the printing head and washed it thoroughly and replaced. I tried the same method of opening the top, turning it on, then closing, and it did go through a routine. When I tried to print, it ground away in its routine for a while but eventually came up with the B203 message again.
I will leave it for a while and try again later but if it doesn't work I'll have to get a new printer. Why does Canon say to take it to a service agent when it's obvious that the only advice you will get is to buy a new printer - and what do I then do with the spare cartidges on the shelf, if the new printer is different?
01-14-2019 12:34 AM
I tried the method. It cleared the error. But once I tried to print again (Macbook Pro wireless), it came back. Unable to print.
Any other suggestions?
01-14-2019 09:50 AM
Mine cleared and I am able to print. However, the print quality is way below par. Somewhat similar to the Draft Setting. Thought I would bite the bullet and get another printer. But try to find one that rates above 3 stars and you will need several cups of coffee. Seems like everything available is just slightly better than junk.
01-14-2019 02:39 PM
Exactly. And I refuse to buy an HP. Swore off them 4 years ago with their tech support mantra, "no worries, just buy another one."
01-14-2019 06:43 PM
I'm afraid I've given up and bought a new printer - a Brother model, recommended by an IT-savvy friend. I was warned not to touch HP.
03-15-2019 10:30 AM
Like others who have commented on this thread, my MG7520 also just stopped working with a B203 error code after 3 years. Contacted Canon Phone Support and they confirmed it was cheaper to buy a replacement than trying to repair. In fact, they have an "upgrade" program setup to offer a new printer at a discount to replace the non-functional one. Apparently these models Canon is selling are disposable printers. So I bought another disposable printer to get me thru next few months while I shop for another more reliable longer term solution.
04-16-2019 09:55 AM
My understanding is that this problem is due to a clogged print head, which makes sense in my case because I hadn't used my printer in over a month because I had run out of black ink. I had just purchased new ink for it and after installing, I got the B203 error.
I removed the print head following the instructions here. I then removed the oval shaped gaskets from the printhead where the ink wells seat against the printhead. Using cotton swabs and alcohol, I cleaned the printhead thoroughly.
I put a drop of alcohol on the ink inlets (where the gaskets were) and using a syringe and a bit of tubing, I was able to force the alcohol into the printhead. This got messy as the ink that was inside it was forced out the other side. I cleaned up the mess and put the printhead back. It was a bit tricky to get the printhead back in, but the instructions will help align things.
Once everything was back together, I restarted the printer and ran a cleaning cycle.
04-16-2019 10:05 AM
In my case, I was actively using the printer and the print head was not clogged. Produced good prints and picture up to 5 minutes before failing. Service tech told me that he thought it was unlikely a clogged printhead but got overheated and some electronic component failed. Even after sitting unused for several hours and manual hard reset, the printer produced this error on power-up. I was also told by a store employee, a inkjet printer expected life is only about 2 years with occasional use. Cost of replacing them at less than $100 is far cheaper than fixing them. Hence as I said before, they are Disposable Printers.
