06-25-2016 01:23 PM
Called Canon Support and they say it's unrepairable but past 1 year so unreplaceable too. Tried everything including dismantling the printhead assembly to manually clean. Barely used the printer, 1 or 2 prints a month.
Anyone have recommendation on non-Canon I can buy to replace for around the same price range?
05-29-2020 04:49 AM
I have had another reply suggesting that a firmware update has potentially fixed the B203 problem.
I am grateful to those who took the time to reply and amazed at the diversity of actions taken in order to gain a fix for this problem, however this same diversity probably indicates they are not a long term solution. Will this also be the fate of a firmware update? Do let me know. This whole senario is identical to the many other Canon Error codes, if you follow the other Posts. I am resigned to losing my DVD printing. Best regards to all. Dated 29/05/2020
07-31-2020 08:58 PM
What method. I don't see it. Thx
08-17-2020 05:45 AM
08-29-2020 05:13 PM
Hello
I just had the same error B203 pop up on my MG7750 display.
I opened the printer cover and turned the printer off, then i turned it back on and as the printhead started moving i closed the printer cartridge cover.
I was now able to get into the printer menu on the printer itself, i went to setup and then did a reset all and after that i go thru the wifi setup on the printer. After that i did a firmware update. And after that a auto printhead allignment.
For now it works, but i wonder how long ?????
Regards Chris
10-27-2020 03:59 AM
To Fix Error B203 Check your ink cartridge:-
Turn off your printer and make sure all the ink cartridges are full. You can pull all the ink cartridges out of the printer and make sure there is plenty of ink in them. Refill the cartridge to resolve the error.Moreover, improper installation of ink tanks can also generate this precise printer issue. Make sure that’s not your case.
01-18-2021 08:49 AM - edited 01-18-2021 09:00 AM
MG5750 giving E203 error code
Just followed the following method on my MG5750, (other repsonses confirm this method may work on other models)
1. Switch Off Machine,
2. Open cover (so you can see cartridges)
3 Turn On Machine,
4. When cartridges start to move Close the Cover
Works a treat "Well it did for me" dont know how long the fix will last for but so far so good.
THANKS
03-25-2021 10:24 AM
What a joke canon is. I will NOT be spending any more money on their products. Getting this code after getting the B204 code and following the prompts to fix. I hardly ever utilize color ink and it happens to be running low and now the entire unit is unusable, unreplaceable and JUNK. it is a SHAME that Canon allows this, just another piece of trash in tha landfill. SHAME ON YOU CANON
03-25-2021 12:12 PM
I have had no problems since the firmware update. Fingers crossed.
03-25-2021 01:19 PM
I will try this, thank you!
08-27-2021 03:14 PM
Worked for me: turn off, turn on with lid open, as soon as the cart moved, closed lid. loaded fine. before this happened 1 ink was low, i replaced it, but didn't fix the B203 error.
