10-26-2024 02:03 AM - edited 10-26-2024 02:06 AM
New IP8720
Installed and works fine.
ADMIN password is supposed to be the serial number.
Yes, the 4 alpha characters are in CAPS
Doesn't work
I have also tried "canon" and every possible combination
10-29-2024 03:59 PM
Hi Chriscal1,
With the later firmware versions, the serial number is no longer the admin password for the iP8720.
To determine the password for your printer, please follow these steps:
1. Turn your iP8720 on.
2. Load a few sheets of plain paper into the the paper feed.
3. Please hold down the Resume button until the Power light blinks 6 times, then let it go.
The Resume button is the middle button.
One page will print.
On the page that printed, the Default Password will appear at the bottom of the list.
https://support.usa.canon.com/kb/s/article/ART115379
12-03-2025 05:35 PM
I finally figured it out:
Username: ADMIN (allcaps)
Pwd: <From the network configuration page printout>
I started a new browser instance, went to the IP address of the printer and used these. The window I had open and tried numerous times wouldn't work so maybe some restriction into the software. Starting fresh worked for me.
Phew - way to painful!
10-29-2024 03:59 PM
Hi Chriscal1,
05-30-2025 11:02 AM
This is not working for the brand new printer i JUST BOUGHT, I AM BEYOND FRUSTRATED HOW DIFFICULT THIS IS!!
05-30-2025 01:41 PM
05-30-2025 02:13 PM
I have done that several times and it just spits out a blank sheet of paper.
11-20-2025 10:26 PM
I did this and printed out the page.
Do I use NO USERNAME, Administrator, administrator, Admin, admin or somethign else
None of them worked using the password printed out
11-29-2025 10:57 PM
No one knows what the username is?
12-03-2025 05:35 PM
12-03-2025 06:32 PM
BINGO! I think the key was using IP vs what the Mac does - the Bonjour ID. First thing I did was remove the admin PWD.
12-03-2025 06:51 PM
ADMIN
