10-27-2022 04:19 AM
I updated last night to MacOS Ventura. Unfortunately, the EOS Utility does not seem to be compatible with the latest version of MacOS. Because of this, I cannot connect with my Canon EOS R6. This is quite disastrous for me, since I use my R6 amongst others as a webcam. Why? In my profession and role, presentation matters a lot.
When will this be resolved? Why is Canon seemingly incapable of keeping their software up-to-date?
De facto, the almost brand-new camera is now not useable anymore.
12-11-2022 06:36 AM
@SteveStone wrote:Hi, this is the version that solved my issue on an intel based iMac, with an R7. Why its a seemingly "older" version I not sure, and why on the Japan site, but it did fix mine.
https://canon.jp/support/software/os/select/dc/EU-Installset-M31613dmg
Yes. 13.16.1 is the latest version. It is available also on the US support site under macOS 12.
12-11-2022 01:41 PM
Indeed the 13.16.13 solves the problem bit surprised its not available on the US site but so long as it works....
12-11-2022 04:22 PM
Thats why I did not see it, I was looking under macOS13
12-11-2022 06:38 AM
Did not work with the Japanese or the Hongkong version. I will continue to use my $44 fire tablet that I modified with google play. Beats the Mac version and is easier to carry around. For photo stacking for astro and macro I may consider building a Raspberry PI interface so I can also control the rail.
12-11-2022 01:44 PM
I just installed that version and it fixed the issue for me, make sure you are not sill using the old version (I had to replace my links to start the newer version)
12-11-2022 01:39 PM
WOW thank you so much SteveStone that indeed solved the problem, I am a bit mystified over why this is not available on the canon usa site but really glad it worked.
12-11-2022 01:55 PM
Available on the US site under macOS 12.
12-11-2022 09:14 AM
There may be a canon hardware issue as well. My 77D and r6 worked before Ventura upgrade, the R6 only work through USB-C. Very slow connection.
12-11-2022 01:46 PM
interesting my USB-C connection is blazing fast, perhaps reformatting your memory card would help
01-16-2023 03:45 PM
I had this issue, solved downloading EOS Utility form Canon Japan (not Europe, not USA)
